Corally Owners Club v1.* >
Old 04-25-2003, 12:53 AM
  #1336
Tom
Tom's Avatar
NOT FROM THE PICS ON THE SITE http://www.corally.com/team/newstm.htm#shapeshifter
ALLOY STEERING BITS (THE ONES OF THE TOP DECK) AND THE GRAPHIT BUMPER BRACE!! NEW REAR HUBS!!
Tom is offline
Old 04-25-2003, 06:27 AM
  #1337
We are trying not to leave anything out on this kit. They may even throw in the break room sink if they can fit it in the box!!!! LOL
Jeff Antle
Corally U.S.A.
JANTLE is offline
Old 04-25-2003, 07:16 AM
  #1338
Thumbs up Great Work!
Jeff,
Keep up the great work!!!!!!!!
Best Regards,
Ken
Superhobby is offline
Old 04-28-2003, 06:35 PM
  #1339
Kevin K's Avatar
Trader Rating: 32 (100%+)
How soon until this car gets over here?
Kevin K is offline
Old 04-28-2003, 07:36 PM
  #1340
Trader Rating: 90 (100%+)
Sign me up. I want it. That single belt with the spur on the rear diff is killer. Mad rip.................... Corraly did some homework on this.
Great work!
RBLove is offline
Old 04-28-2003, 08:11 PM
  #1341
Pembalap's Avatar
What makes me wonder is that the direct drive configuration will have a limit, in term of the final ratio for modified racing. I usually ran 8x2 or 9x1, with ratio of 8.5 to 9.2.
Since the direct drive won't have a reduction on the belt system, the final drive ratio is only a function of Spur and Pinion (Like Pan Car). If I used a 17 teeth pinion, to achieve 9.2 ratio with my 9x1 motor, I need a 153 teet Spur gear (48 pitch)....
Mann....that's a hugeeee spur gear.... It seems that the car will not be able to accomodate a spur that big, or will it?
A.W
Pembalap is offline
Old 04-28-2003, 08:33 PM
  #1342
Pembalap, You will be O.K. The spurs are designed for this car. It is a special gear that bolts on the rear diff so it can be removed easily and replaced with the gear reduction pulley. Again Corally did their homework to provide a car that is unlike any other.
Corally Assassin, powerd by the "one of a kind" SHAPESHIFTER Transmission! Soon to be on the loose at a track near you!!
Thanks,
Jeff Antle
Corally U.S.A.
JANTLE is offline
Old 04-28-2003, 08:45 PM
  #1343
Pembalap's Avatar
Thanks,
Jeff Antle
Corally U.S.A.
Jeff, doesn that mean for the low turn motor, we have to use the dual belt configuration?
A.W
Pembalap is offline
Old 04-28-2003, 08:50 PM
  #1344
No, The spur gear should be able to get you where you need to be. The gear reduction just seems to calm the car down a little bit. There is such a thing as too much rip!!!!
JANTLE is offline
Old 04-28-2003, 09:10 PM
  #1345
Jeff,
Any idea what spur sizes are available for the single belt version? 64 pitch of course
I want this car now. Check your e-mail. I sent you something.
RBLove is offline
Old 04-28-2003, 09:13 PM
  #1346
Rob,
It will be shipped with the 48 pitch gears. I believe that they are going to add 64 pitch shortly.
JANTLE is offline
Old 04-28-2003, 09:34 PM
  #1347
Pembalap's Avatar
Rob,
What will the number of tooth on the included spur gear?
A.W
Pembalap is offline
Old 04-28-2003, 09:40 PM
  #1348
Sorry, I do not remember what the exact size is. I will find out for you though. Since they are very busy getting the new kits ready it may take a while to get the answer. I will post it as soon as I get the correct answer for the production kits. It was of a healthy size if I remember correctly. Everything else in the kit has been looked at many times. This is not something that was overlooked. You will be O.K.
JANTLE is offline
Old 04-28-2003, 09:46 PM
  #1349
Kevin K's Avatar
Jeff any word on a street price for the car yet?
Kevin K is offline
Old 04-28-2003, 09:57 PM
  #1350
Not yet. We hope to have it by the end of the week as the RCX show is comming up and we will need the new price sheets for the show. The NEW Assassin will also be on display at the show!!!
Any one near should stop by to see it in person!!!!!
JANTLE is offline
