Corally Owners Club v1.* >
Old 05-01-2003, 05:38 PM
  #1366
trackdesigner71's Avatar
I dont know what to use to remove the thing Jeff (Sorry if I sound a little annoyed)
trackdesigner71 is offline
Old 05-01-2003, 07:34 PM
  #1367
Does yours have the black plastic finger clips or the rubber O ring? The black finger clips should just snap off. The rubber O rings you have to work for. use a small flat head screw driver to pry the O ring off of the the axel for the front. For the rear it should be the finger clips and they should just unsnap like an E clip. The clips are on the outside of the wheel on the axel not on the inside of it. If not e-mail me a picture of the wheel you are trying to get off so I can get a better look at it. Just click e-mail on the box and shoot me a picture if you can.
JANTLE is offline
Old 05-01-2003, 11:06 PM
  #1368
PizzaDude's Avatar
Ray,
Boxstock it is pretty stiff.
Probably that rubber(tire) racers will opt to remove 1 of the small bridges in the top deck.
They made some connectiones between left and right, which can be easily cut away.
PizzaDude is offline
Old 05-02-2003, 11:59 AM
  #1369
rayhuang's Avatar
pizzadude-thanks!! Its gotta be stiff or I know I'll have problems at big races or at my track when entries go to 80 to 100 per race in the fall!!!
Ray
rayhuang is offline
Old 05-02-2003, 03:12 PM
  #1370
PizzaDude's Avatar
Ray,
The mid motr hop-up (later available) might make the car even stiffer.
One of it's nicest features is the balancing weights...
You can place them anywhere, so you'll be able to balance you're ride perfectly.
AND at the absolute lowest possible place.
inside the chassis....
Old 05-02-2003, 03:15 PM
  #1371
Default TEAM FORUM
NEW CORALLY FORUM
Here is a link to the New Forum, set-up to get more direct answers to Corally questions...
ECHOLogic is offline
Old 05-06-2003, 11:53 AM
  #1372
Arrow
