Tamiya XV-01
#1636
This is good to know, I just placed an order for the longer damper towers! Which means more rally.
A question, when using the longer dampers in conjunction with the damper towers, do I need to use the long or short damper ends?
I guess I will found out when all the pieces arrive in the mail.
#1637
my goal was to have a shock package that would give the most potential droop, and still give full up travel letting the chassis bottom before the shocks. Using standard length shocks with the long rod ends gives lots of droop, but running with standard towers the shocks bottom out before the chassis, not good.
I would assume running the tall towers and longer shocks the short ends would be best. the long rod ends add droop, but they dont compensate with more up travel as well.
#1638
ThePanda. any link to those shocks?
#1639
I bought mine direct from tamiya.
you will need X2 of these for the front bodies https://www.tamiyausa.com/product/it...uct-id=9404701
X1 of these for the small plastic bits
https://www.tamiyausa.com/product/it...oduct-id=51282
X1 of these for the shock caps
https://www.tamiyausa.com/items/radi...-v-parts-51280
#1640
Nice!
Speaking of which, I saw this part for the XV, 54480 Tamiya 1 mm Separate Suspension Mount Setting Spacer (4 pcs) & want to ask what it this for exactly?
I know where it is supposed to fit on the chassis but what does it do?
#1641
Roll centre
Front Kick-up / Anti-Dive
Front Pro-Dive
Rear Anti-Squat
Rear Pro-Squat
Cheers.
#1642
By using the shims under the suspension blocks, a side affect is getting a little more droop from the A-arms. Coupled with a longer stroke damper can give more ground clearance.
#1643
Long Damper on Xv-01TC
I went ahead and did it. I bought the xv-01 long damper towers. They are pretty tall. So much so that they reach beyond my projected CVA dampers that are 67mm. With the modifications I've made for maximum TC arm droop, i had to scavenge some really long dampers from my crawler and also put long ends to reach maximum droop. A total of 80mm center of holes to center.
I am using some Team Associated medium length springs, which are little soft for on road driving with a very pronounced dive under heavy braking.
However for off road, the long travel and buggy springs produce a very plush feeling, I would equate it to a Baja truck soaking up the terrain. Pretty cool to watch. The 75mm tires also help in this aspect.
The maximum ride height with the larger tires doesn't change in my case and is roughly 30mm. The main thing that changed is the upswing of the a-arm is significantly increased.
So far so good. I want to get some nicer dampers. Anyone have any suggestions for a 80mm damper?
I had looked at gmade XD 75mm. But the car really needs 80mm for the rear.
Now, that my curiosity has been quenched, I wonder if it's worth it for this whole conversion?
Long spec Damper towers and new dampers can be an expensive upgrade. While they add nice bling to the chassis, the only real gain from my stand point is that the a-arm and base of the tires can travel higher than the chassis. I suppose for really rough off road this is desirable as the car would pitch and roll more. But for smooth off road and on road does this help? Possibly. I have noticed that all my on road cars are designed in a way that the a-arm upswing is far greater than the downward travel. Does anyone know about this and how it affects the handling?
#1645
In a raised chassis like that for rally, it still makes sense to have the suspension travel up higher than the bottom of the chassis for bigger bumps.
If the suspension bottoms out at the same point the chassis does, the cars stability may be compromised by a bump greater than the ride height. This is why upward travel beyond the chassis bottoming out is useful.
#1647
What is the Tamiya TRF Damper that is equivalent or if not better than the damper that comes with the Long Damper Kit?
#1648
XV-01TC-LD spec
Hi all,
It's been a while, but I've comeback with a modified long damper spec conversion of my Xv-01TC armed rally machine.
I bought some gmade XD dampers which are really nice. The length at 75mm. These dampers are big bore and big springed. The mounting needs a little modification since the cap doesn't take a ball joint. I am using the long Tamiya damper ends.
The springs are a tad soft for road rally, but for rutty grass, it works very well.
The damper towers are extremely tall compared to the stock towers. Therefore you will need an upgraded or longer damper about 75-80mm hole to hole.
In all honesty the amount of travel isn't anything that you can't do with the shorter towers. I get almost as much travel and ride height with 55-60mm dampers and long damper ends on the stock damper towers.
I am not sure what Tamiya was thinking other than getting a significant amount of money from me. I will say that the aftermarket carbon towers are nice to look at and are constructed with high quality. Otherwise you might want to just run what you have and make some suspension mods to get better ride height if that is your goal.
All and all its not bad. Just an expensive experiment to get a little more up travel.
#1650
Spring Color Code
I settled on Yellows in the front and Reds in the rear for my front-motor XV-01. The reason I use Yellows in the front instead of Blues is because I'm running much thicker oil in the front, so the front suspension can be more compliant for better traction in corners, while still resisting bottoming-out on sharp impacts like running over the edge of a sidewalk slab that's sticking up a little
On my long-damper rally builds, I use the TRF201 front-shock tuning springs, with Blues in the front and Reds in the rear.
I found out the colors are
Hard (green), Medium (black), and Soft (brown)
How come the color you mentioned is not the same?
