Tamiya TA05 Touring Sedan
#8867
#8868
with spool is there any adjustment we should do?? like downstop, shock oil or shock position ???
#8869
Gives a very stable, yet drivable feel to it. Gets the tyres and suspension working, rather than just relying on the tyres too much
As for droop I am not running any on the rear, cant remember on the front but its very little/none at all if my memory serves me right
#8870
thanks...
#8873
ok
i will then
Version 2
width: (bottom deck(did not include hump for movable servo mount)) 11.2cm
thickness: (bottom deck) 1.8mm (top deck) 1.8mm
Version 1
width: (bottom deck) 12.9cm
thickness: (bottom deck) 3mm (top deck) 2.3mm
Cant think of any more so just contact a say exactly where it need to be measures
i will then
Version 2
Version 1
#8878
It will fit fine, It is what I use. I added some weights under the battery to get the weight up for TCS racing. It will also help the battery sit level since there will be a bit of a gap from the bottom of the chassis from the ends of the battery holes that go up some (the battery will sit on top of the higher parts on the sides. I dont see any reason it will not fit the B4 since it is prob the same size as any normal battery.
