Tamiya TA05 Touring Sedan >
Like Tree72Likes
Old 07-11-2005, 06:04 PM
  #631
vi3tishduy's Avatar
I'm ordering my TA05 tommorow. Is the chassis that "soft"?
vi3tishduy is offline
Old 07-11-2005, 06:09 PM
  #632
izzyracer's Avatar
Trader Rating: 27 (100%+)
That's a matter of opinion as you can see. The facts are the material is made and designed better compared to what we are use with Tamiya. When all is put together and all of the electronics are installe, you will see very very little flex, but it is there. For the price, it's worth the money.
izzyracer is offline
Old 07-11-2005, 06:29 PM
  #633
fire929's Avatar
Default Susp mounts
Which Suspemsion mounts will fit the front and rear of the TA05 (415)?
fire929 is offline
Old 07-11-2005, 06:36 PM
  #634
izzyracer's Avatar
You will need the 415 bridge blocks for the inside front and rear to clear the belts.
You can use 415 or from evo4 but you might want to ad spacers if you will be using the evo4's.
Old 07-11-2005, 06:49 PM
  #635
rayhuang's Avatar
Yup-you said a mouthful. I know that I will have one very soon. Just waiting for one of you guys to sell me one with all the hop-ups already installed!!!
rayhuang is offline
Old 07-11-2005, 07:02 PM
  #636
rayman's Avatar
Is it really heavy? Cant wait till its sold at my LHS. Cant believe its made in Phils yet I have to wait till its available here. How ironic! What's the yen price? Hopefully its not as heavy as my tbo2.
My 3D Gallery Website
rayman is offline
Old 07-11-2005, 07:08 PM
  #637
Originally Posted by rayman
Is it really heavy?
Out of the box, with protoform body, sorex wheels, KO VFS speedie, HRS Receiver, Futaba 9550, Monster motor and IB3600's my car weighed 1540. So i wouldnt classify it as a pig.
Besercoe is offline
Old 07-11-2005, 07:13 PM
  #638
ttso's Avatar
Default ESC.. again
Finally, I got my SS ESC mounted on TA05. It need 8mm rubber under ESC to mount it higher for more space.
As for "soft", indeed after everything on, the chassis flex is ok, but still no good for my standard. However, damper tower is really way too soft and there is nothing to fix it except CF hopup. Seriously I suggest everyone going to race TA05 get CF damper tower as a must.
ttso is offline
  #639
izzyracer's Avatar
[QUOTE=rayman]Hopefully its not as heavy as my tbo2.
[QUOTE]
ummmm... it is.
Old 07-11-2005, 07:32 PM
  #640
ttso's Avatar
3mm shim on left side should fit in 415 front bulkhead very well.
I can't use my 415 spool on TA05...
Originally Posted by Nexus
RC TA05 High Precision Diff
Item #53849
Any chance that fits the front of a 415?
Just thought I'd ask in case someone here owns both a TA05 and 415.
ttso is offline
Old 07-11-2005, 07:36 PM
  #641
ttso's Avatar
old suspension = TA04, 414, 415, TA05
new suspension = LW suspension = EVO4, 415MS, EVO4MS, TB02R
will photo the different of wheel axle after I get home tonight.
Originally Posted by Ballsie
Thanks - I take it you mean NEW axles - Evo IV / 415 MS
OLD axles - 415 / 414 / Evo III etc.
Cheers.
ttso is offline
Old 07-11-2005, 07:41 PM
  #642
fire929's Avatar
Default thanx
thank u
fire929 is offline
Old 07-11-2005, 08:50 PM
  #643
[QUOTE=izzyracer][QUOTE=rayman]Hopefully its not as heavy as my tbo2.
ummmm... it is.
Champ how about you quantify what you regard as "Heavy", per above, kit out of the box ready to race was 1540 grams, 40 grams shouldnt be too hard to get rid of with Hop up hardware.
Besercoe is offline
Old 07-11-2005, 08:53 PM
  #644
Turbonium's Avatar
Originally Posted by rccardr
Wes, your car looked super this weekend. I gotta get me one of them for next season!
thanks Doc!!
it was really good, especially considering i made very few adjustments from kit....
i may have been able to catch ya (without all my mistakes!), but anyone who has raced with Doc knows... catching and passin are 2 different things!!!! yearite... nobody had anything for you!!!!!
and i did, uh, stress test a bit in that "Widowmaker" chicane with a 19T a couple times.. no broken parts! the towers are quite flexible, but probably not a problem unless on very high bite stuff, carpet, etc.
Turbonium is offline
Old 07-11-2005, 10:04 PM
  #645
vi3tishduy's Avatar
Hello folks! Hebiki thanks again man! Ok about the TA05, is stifness better or worse for asphault or is flex better for asphault? Also, would you guys happen to know good esc fans and part numbers? Does Tamiya have any? Thanks!
