Tamiya TA05 Touring Sedan
#5131
Originally Posted by MK_Arbiter
I guess so, because Tamiya is a japanese company.
I should've stayed in Japan to get all the rc stuff cheaper.
#5132
Weight of chassis..
Hi,
just wondering, how heavy is the overall weight of the TA05 out of the box? Is a "weight loss" programe need to be dont on the TA05?
#5133
In japan, I bought my TA-05 with a futaba 2PHKA radio and an MC330CR speed control all for 20000 yen around 200 canadian. I miss japan.
#5134
also, i want to know the Spur gear that comes in the box, is it 64 pitch or 48 pitch?
#5136
#5137
My input: I've been using 48 pitch pinions with the stock spur gear for a while with no problem. I built the car with a standard, 48p, 72t spur but rocks made quick work of that. I figured, what the hell...doesn't cost to try the one that came with it
#5138
Hi,
#5139
Originally Posted by Slotmachine
It`s a metric pitch like 48
On the other hand Tamiya 0.4 module and 64dp are very close.
#5143
I have a set of RD Logic's wrenches and they are so tight in the screws you have to wiggle them into them. Best wrenches I ever bought..................
http://www.rdlogics.com/cgi-bin/cate...i?item=76200BM
#5144
Originally Posted by DA_cookie_monst
Joys of Aluminium screws I'm afraid Josh.
#5145
Part #?
Originally Posted by CIVIC91
It uses 9 balls instead of 8, has a beefier build and half the teeth. For thr 3 bux they cost, I would just pick them up..the time it would take to remove the teeth from the standard one wouldn't be worth it.
