Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 04-19-2006, 01:47 PM
  #3901
should i do a simple website for all the different setups for the 05 that you guys have being doing and trying out and it saves everyone going throught all the thread (130 pages) and i might pm people with the password etc so they can go on and post there setups???
TAMIYAMANUK is offline
Old 04-19-2006, 01:59 PM
  #3902
Slotmachine's Avatar
I just picked up the Xenon chassis , motor mount and top plate. This thing is 20g. heavier with all the supports chassis braces and screws then the stock chassis is with only the chassis braces. This chassis will bring the car well under weight so I can put weight anywhere I want it.
When I get the aluminum diff halves in I will finish the build up.
Paul.............................................. ...............................
Slotmachine is offline
Old 04-19-2006, 02:21 PM
  #3903
Viat's Avatar
Trader Rating: 24 (100%+)
Does any body know how long the Take-off's are lasting on a track like in Frederick, MD at "Hobby Town USA" if using 27t motor?
Viat is offline
Old 04-19-2006, 02:25 PM
  #3904
Originally Posted by Viat
Does any body know how long the Take-offs are lasting on a track like in Frederick, MD at "Hobby Town USA" if using 27t motor?
At least 3 weeks at an A main pace. If you are not running in the 11.5`s or faster then 5 weeks or more. If the car is not sliding around the corner.
Old 04-19-2006, 02:28 PM
  #3905
Viat's Avatar
All right, how about B3's
Viat is offline
Old 04-19-2006, 08:21 PM
  #3906
cheehtae's Avatar
Trader Rating: 15 (100%+)
I second that.Great Idea.
cheehtae is offline
Old 04-19-2006, 09:06 PM
  #3907
danjoy25's Avatar
Trader Rating: 38 (100%+)
That would be good. TCS rules here downunder was just released today and Ta05 & TB02 are the top spec cars allowed in GT1 class.
danjoy25 is offline
Old 04-19-2006, 09:21 PM
  #3908
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
shoot I have some premount cs-27's that are over a year ols and they are still holding up. Then again I can't drive so it doesn't matter. They sure do last a long time
minicooper is offline
Old 04-19-2006, 10:27 PM
  #3909
big al's Avatar
Hey Slot, I rec'd my screws today and was able to drop 15 grams with just the flat head screws alone!! I figure I can drop another 5-8 grams once I order an install the alum. button heads. The 15 bucks was worth it!!! My wife even said, "how cool".
big al is offline
Old 04-19-2006, 11:52 PM
  #3910
danjoy25's Avatar
Anyone here that post frequently in RCtech that ran a TA05 in TCS? Reveal yourself. Only podium finishers are needed. I need some setup tips.
danjoy25 is offline
Old 04-20-2006, 05:52 AM
  #3911
Steven Key's Avatar
you running rwd mini as well? any ideas on setup for that? prolly outta use pms for this off topic discussion...
Wes,
I do plan to run RWD Mini but I haven't run on pavement since the nationals in 03. The RWD cars were not competitive at that event because of the gear rules. I ran my FWD MO3L last time at Memphis and ended up mid pack in the A. PM me for ideas.
Hey wait this is the TA05 site. Any suggestions on gear ratio for a TA05 at Memphis?
See you in Memphis.
Steven Key is offline
Old 04-20-2006, 06:04 AM
  #3912
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
my car was borrowed and subsequently won gt2 and gt3 @ frederick last mth. very pleased w/the tweakin they did.
-ult
UltegraSTI is offline
Old 04-20-2006, 06:13 AM
  #3913
Thats great! I`m glad I could help add some cheap bling to your car.
Old 04-20-2006, 07:26 AM
  #3914
rampal's Avatar
Hey Slotmachine, 15 bucks for an Aluminium Screw set for the TA05? Where? I've seen the titanium one (#49360 aroun 40 bucks) on ebay, but no aluminium and I need to take weight off the TA05.... right now it is heavier than my TT01 hopped up!!! However, they cannot be compared, the 05 is amazingly smoother than my tt01 AND my Mission!! To take some weight off (I already have TRF shocks and sway bars) I'm thinking on:
- carbon shock stays
- carbon battery plate
- aluminum turnbucles
Do you think that with help to take let's say around 60 grams off? I plan to buy a Futaba s9550 servo that is 15 grams heavier than my current one
Finally, is the #49360 an metric hex set? 2mm driver??
thanks a lot, cheers,
rampal is offline
Old 04-20-2006, 07:39 AM
  #3915
Core Creations's Avatar
Trader Rating: 108 (100%+)
www.fastener-express.com sells them in bulk
Core Creations is offline
