Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 03-16-2006, 12:10 PM
  #3451
f1larry's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Nexus
F1Larry...Your son might be whooping you now with the 05!
Nexus,
If he keeps driving it like he did on Sunday it won't be long till he does.
The car looked great and there isn't a single hop up on it yet.
L8R
f1larry is offline
Old 03-16-2006, 02:18 PM
  #3452
Question
Hi TA05 racers,
I plan to buy the new option part Tamiya Reversible LW suspension kit for TA05 ref 53899,
which swingshaft length should I buy ? 42mm - 46mm or 48mm
thanks for your support !
Ralf is offline
Old 03-16-2006, 02:29 PM
  #3453
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Ralf
Hi TA05 racers,
46mm
OOPS.. EDIT... 48mm if you are using the standard blocks... 46mm for the narrower ones.
Hebiki is offline
  #3454
OSherman's Avatar
Hi TA05 racers,
Instructions specify 48mm.. Just got mine, gonna assemble tonight..
OSherman is offline
Old 03-16-2006, 02:41 PM
  #3455
Thanks Hebiki
Ralf is offline
Old 03-18-2006, 07:04 PM
  #3456
Formula1fan's Avatar
I want to put some foams on my 05 and see what this baby can do, but it looks like the front rim is too close to the ball cup on the front. Anyone running foams how have you got past this problem?
Formula1fan is offline
Old 03-18-2006, 07:45 PM
  #3457
I'm currently building mine, but I can't get the RX antenna into the antenna tube. It goes in half way, but then it just gets too hard to push in. There's nothing stuck in there. It's my first car, so I'm guessing there's usually some tricks to getting it in?
Also, I bought the universal shaft hopups. Are these actually much help since they're made of plastic and the stock ones are metal? Thanks.
Seatbelt is offline
Old 03-18-2006, 07:47 PM
  #3458
Core Creations's Avatar
Trader Rating: 108 (100%+)
Just run some shims in the front. The axles on the 05 are extra long, so you can put 1.5mm worth of shims on each side and then it should just clear the foams. I also shave just a hair off the outside ball cup for an extra 1/2 mm or so of clearance. I personally don't like cutting down 28mm foams to 26 or 27 to clear it. I run the 6mm aluminum hexes with a 0.5mm shim. The stock plastic hexes are 5mm.
Core Creations is offline
Old 03-18-2006, 07:55 PM
  #3459
thanks
Old 03-18-2006, 09:35 PM
  #3460
Regional Moderator
Darkseid's Avatar
First, straighten out the antenna as much as possible. Antenna usually come bundled up, so just run your fingers down it a couple times to straighten it some. Don't tug too hard though, you don't want to break the antenna. Then to get it through the tube, just take a little shock oil, rub it between your fingers, then slide the antenna through your fingers. Then try sliding it through the tube, it should go right through.
Your universals shouldn't be made of plastic. If you bought the right hopup, they should be made of metal. It may be dull color black or something, but it should still be made of metal.
Darkseid is offline
Old 03-18-2006, 10:36 PM
  #3461
Awesome darkseid. I thought about that, but is there any chance that the shock oil could interfere with the radio reception?
Seatbelt is offline
Old 03-19-2006, 01:23 AM
  #3462
It will be fine, anything that makes it slippery, I have even used a little spit down the top of the tube at times, lol.
DA_cookie_monst is offline
Old 03-19-2006, 05:05 AM
  #3463
eeewww
Old 03-19-2006, 05:10 AM
  #3464
needs must... lol, far less messy than trying to get WD40 down there, lol
Old 03-20-2006, 05:11 AM
  #3465
Leester's Avatar
Trader Rating: 23 (96%+)
Has anybody ran a carbon fiber chassis on a TA05 yet? I'm getting a 3 racing Carbon fiber chassis and i'm wondering if i'm going to see a very good improvemnt in performance.
-Lee
Leester is offline
