Tamiya TA05 Touring Sedan
#3331
Originally Posted by Hebiki
i think i got lucky. my carbon tub is only tweaked .5mm
ill fix it with droop, and other settings. anyone run on rubber/asphalt yet? any impressions? (izzy? )
#3334
Originally Posted by maxepower
If the binary is the RPM version then you will want to gear in between 7.0-8.0 final ratio. Which would be 29 to 34 pinions.
I'll start with the 31 I already have and tune from there.
I had been running my TC3 with 48p and don't have a collection of 64p yet.
Saturday night should be the debut of my stock TA05. The only modifications I will make are:
- Foam tires
- Different shock oil, but stock plastic shocks (probably 70/50)
- Hex screws
- 27t stock motor
- 64p spur and pinion
If I get the Mercedes body painted in time, I'll even run the kit body. Otherwise I'll ream extra holes in an older Alpha or something else I have hanging around.
I know it won't be ideal, but I want to see how the stock kit compares to the TC3 I was running (FT with IRS diffs/CVDs, etc...) and see how it runs with the Xrays and RDXs at the track.
I expect I'll add sway bar(s) and possibly change the shocks at some point.
This thread has been instrumental in convincing me to try this kit and I'm sure there will be lots of help when I need it
#3335
Regional Moderator
Originally Posted by Batfish
Thank you, maxepower.
- Foam tires
- Hex screws
- 27t stock motor
- Foam tires
- Hex screws
- 27t stock motor
The best part is, with a car that works so good in stock form, you can take your time and add the hop ups as you wish(or as budget allows )
Good luck to you Saturday night.
#3336
Just received my graphite chassis and it is tweaked. That sucks, but still won’t deter me from such a great car. I tried a PRO4 when everyone told me not to and man was I sorry. That thing had a wicked tweak in it. I ran my TA05 one time at the TCS and fell in love with it. I will she how it goes with this chassis. Can’t wait to put some foams on it and see how it handles with real traction.
#3337
Hey F1, you or Sean heading to MD in 2 weeks for the TCS? I'll be there with my MSX for GT1. I'm letting someone borrow my TA05 for GT2. I just got in all the "graphite" parts. And checking an unmounted chassis on a glass table... the front left is a hair high. Every other corner is flat. I'll have to see how things are once I have everything mounted inside. If the left front is still high... I'll just set 0.5mm more to the ride height reading compared the other corners.
#3338
#3339
weight savings
plastic tub vs. graphite tub.. you save 20 grams
graphite tub also has slots for using tape! DIALED!
#3340
I know what you mean about tires. I ordered $100 worth
(5 full sets) of just tires from Japan yesterday... That doesn't include rims or inserts. But I'm selling 2 of those sets to a friend. Plus I have some left over from last year for practice. Alittle tire maintance and they'll be like new again..
Anyways, catch ya in July then....
#3341
tweak
i also wonder how much harder it is to put those machine screws into the graphite material... when i get the graphite tub should i thread the holes with the regular steel screws first ?
#3342
Does the tweak happened on stock and carbon tube chassis ?
I didn't notice 'cause I bought mine used...
#3343
Originally Posted by quantum
my kit chassis is currently tweaked in the exact same place - with everything installed the front left, and also rear right are slightly higher (wonder if its in the way its molded?). i'm still able to be quite competitive BUT must put the darn car on a diet...
the graphite tubs are the ones that are tweaked. the plastic ones are fine.
#3344
But visual presentation will be much help....
Anyone still has NIB graphite lower deck ? and have pictures showed the tweak parts ?
#3345
Regional Moderator
But now that I have taken the kit tub off, I can clearly si that its tweaked.
But it just didn't matter, the car still handled great. Which is why I wonder why people are so concerned about it now.
