Team CRC Xti 1/12th Scale!!
#1006
.55 fronts
.402 kingpin
5 degree blocks
all shims forward
-.5 degree camber
long arm
shock all the way forward
batter forward/middle
white center
white sides just touching
20k
magenta front 41mm
pink rear 42mm
#1007
I have never run inline and probably never will. For a European layout I would use the Altered Ego kit. This is what i would start with.
.55 fronts
.402 kingpin
5 degree blocks
all shims forward
-.5 degree camber
long arm
white center
20k
magenta front 41mm
pink rear 42mm
.55 fronts
.402 kingpin
5 degree blocks
all shims forward
-.5 degree camber
long arm
white center
20k
magenta front 41mm
pink rear 42mm
.55 smoothen out the steering? due to long arms ( maybe over thinking a little here )
Plan to run Alter Ego just wanted to actually get a feel for an inline setup aka kit design. Hearing that people are going back to Xi or running using Alter Ego guess there is a reason ..
Other notes the use of CRC33401 on the left of the rear pod stiffening up the rear pod is this a popular tweak?
Another note is the use of shims to raise lower half of the shock, anything from .3mm to 3.5mm
#1008
I just ran the standard left pod on the car and it works perfectly. Assemble your rear pod and make sure it isn't tweaked. Then attach it to the main chassis.
As for the shimming of the shock I usually run 2mm under the front. A flatter shock gives you more on power steering. Higher gives you less on power steering.
#1010
Sometimes I get stuck on an idea. Well this happened this time... yeah I know it's not Xti and I need to remove some more material from my custom shock mount... but it is a CRC and it's you guys who would think it was cool.
http://i.imgur.com/o9zzF1j.jpg
#1011
Got a chance to race my XTi this weekend, this was only my 3rd time getting to run the car, the car ran pretty good, still working on a setup for my driving style, but so far I have had 2 rear lower pod plates to break from light taps, this is something I never had happen with my GenXL and it had a lot more races and crashes on it, the car has a lot of steering which I like, but seems to be more fragile. Ive seen several other post about the pod plate breaking is there any solution to help with this issue?
Thanks in advance
Thanks in advance
#1012
altered ego - short pod or long one
Max,
Do you prefer the short XTI pod on your altered ego? Or do you run with the newer version longer altered ego pod?
.55 fronts
.402 kingpin
5 degree blocks
all shims forward
-.5 degree camber
long arm
white center
20k
magenta front 41mm
pink rear 42mm
.55 fronts
.402 kingpin
5 degree blocks
all shims forward
-.5 degree camber
long arm
white center
20k
magenta front 41mm
pink rear 42mm
#1013
#1014
Thanks in advance
Thanks in advance
#1015
I found a good source for the Sanwa SRG-HR. Took only 10 days to get here from Poland and shipping was cheap.
#1016
I keep hearing that a heftier rear pod plate is what's available, I'm on number three and see no change to material or workmanship? Perhaps my latest is just old inventory? Has anyone seen a new and improved rear pod plate?
#1017
Is it worth changing the plastic standoff for the xl version ?
#1018
hi all - not sure if this is the 100% correct thread, but I'll ask anyways
has anyone use the conversion kit to take a gen-xl to the gen-xi specs?? If so, did it make your car better??
I need to get a new chassis for my gen-xl, saw this and it has me curious
thanks!
thanks!
#1019
