Team CRC Xti 1/12th Scale!! >
Like Tree221Likes
    Hide Wikipost
Old 03-02-2021, 05:42 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team CRC Xti 1/12th Scale!!
Last edit by: tobamiester
Old 10-14-2012, 11:53 AM
  #256
LonnyJ1950's Avatar
I use the shorty pack on a track that varies from low to medium high traction, mildly technical, and the most I use is 2500 mah or so. Lots of power, little loss of performance over the 8 minutes.
LonnyJ1950 is offline
Old 10-14-2012, 01:27 PM
  #257
theatriks's Avatar
Originally Posted by InspGadgt
Yes I was using the 4200mah shorty pack. When I get my Xti I plan to go back to a normal sized 1 cell pack.
Why are you switching back to a normal sized one .....btw the xti will be my very first 12 scale once I get it so sorry for all the questions
theatriks is offline
Old 10-14-2012, 04:45 PM
  #258
dougo96's Avatar
Originally Posted by theatriks
Also are these in stock at calandra ?.....im getting sick of waiting for horizon to get these in stock.
http://www.teamcrc.com/crc/modules.p...prodID=7719205
dougo96 is offline
Old 10-15-2012, 07:09 AM
  #259
Originally Posted by smyka
BIGTEE send me a text 860 716 5720 i can never get pictures to post here
as for setup this is what i ran and kenny was clost i believe his frontend was a touch different
front
10 degree reactive but raised 2mm (between arm and reac. block )
two shims back one forward
crc graphite brace across top arms
short arm .5 camber
50 front springs 15k lube on king pin
.5 toe out in nose
middle
stock kit white spring front raised .30
30 wt oil
.5mm droop
rear
20k tube lube
associated blue side springs just touching then tweak
rear max roar width
standered xti configuration (battery inline)
for tires i ran bsr white rears(crc yellow) and grey fronts with saftey glue only
crc black art body mounted 2 mm more forward then stock holes
my car weighted 732 grams with 7 grams added to left side rear
Thanks for posting this
malkiy is offline
Old 10-15-2012, 08:55 AM
  #260
Swampracer's Avatar
Trader Rating: 72 (99%+)
Default Tire glue
What is everyone using for glue to do the sidewalks?
The glue I have used cracks the foam
Thanks Greg G
Swampracer is offline
Old 10-15-2012, 09:44 AM
  #261
front
short arm .5 camber
.5 toe out in nose
middle
30 wt oil
.5mm droop
rear
20k tube lube
rear max roar width
Interesting tire choice... Did you try Black or Chrome/Grey&Black fronts as well? If so, how did the straight Greys compare?
JamesL_71 is offline
Old 10-15-2012, 10:04 AM
  #262
AdrianM's Avatar
Thanks Greg G
A light coat of thin CA. I think it should like like matte black foam if its right. if its thick and shiny you overdid it and it will crack.
I slightly bevel my sidewalls a couple of degrees so the foam wont hit the barriers in a crash, CA the sidewall then true the tire to size and round the edges. I end up with a 1mm band of CA'd foam next to the rim.
AdrianM is offline
Old 10-15-2012, 10:29 AM
  #263
Coming off the track with very little left in the battery I was seeing some fall off in power in 13.5. Plus with the full sized pack it will be easier to make minimum weight.
InspGadgt is offline
Old 10-15-2012, 10:34 AM
  #264
theatriks's Avatar
Gotcha !
Old 10-16-2012, 05:39 AM
  #265
What do you guys think about using these.
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Tim3 is offline
Old 10-16-2012, 07:39 AM
  #266
AdrianM's Avatar
A few guys at my track have those. They all say they are great. A couple of them say they are the best packs they own. Note that they have not been submitter to ROAR and are not legal if you race at a ROAR track or at events that follow ROAR rules.
AdrianM is offline
Old 10-16-2012, 07:54 AM
  #267
Da! I see this now. thanks
Tim3 is offline
Old 10-16-2012, 08:01 AM
  #268
smyka's Avatar
Sorry been bust at work as for glue I have always used losi blue it just seems to be the best for this it stays on top of foam until it hardens
As for tires I ran every combo I could think of pink/d-pink white d- pink white /black white dual fronts white/grey rears and different fronts and I found traction staringe this year my "rubber based" tires would start off pushy loose then get a ton of front bite so I went to "foam" base tires and it was better just needed to find the right steering blacks were good after three laps but very "twitchie" up front dual fronts were really good but I only had two pair so I tryed Grays with safety glue on edge and from first lap till end traction was good
smyka is offline
Old 10-16-2012, 08:28 AM
  #269
Could this be a good CA glue for the tires, its flexible .
http://www.hobbyking.com/hobbyking/s...n_CA_1_oz.html
Tim3 is offline
Old 10-16-2012, 08:36 AM
  #270
theatriks's Avatar
Does anybody know if this car is in stock at calandra?
