Team CRC Xti 1/12th Scale!!
#228
13.5 CRC XTI transverse
.55 front spring
.404 king pin length
5 degree caster
.5 degree camber
Crc red center spring
30wt oil in center shock
4mm pod.droop
3.5mm ride height. Front , center and rear.
Magenta front tire
Magenta rear tire
White side springs 1.5 turns down... Fairly compressed
50000 dampner tube lube
Crc.black art audi r8c body
Hobbywing 1s speedo
Trinity d3.5
Revtech batteries
Spektrum radio
Crc xti inline .55 front spring
5 degree caster
.5 degree camber
Crc black center spring
2mm pod.droop
Magenta front tire
pink rear tire
blue side springs just touching
20000 dampner tube lube
Protoform amr
Lrp sxx v2
Trinity d3.5
Revtech batteries
Spektrum radio
.55 front spring
5 degree caster
.5 degree camber
4mm pod.droop
Magenta front tire
Magenta rear tire
Hobbywing 1s speedo
Trinity d3.5
Revtech batteries
Spektrum radio
5 degree caster
.5 degree camber
2mm pod.droop
Magenta front tire
pink rear tire
Protoform amr
Lrp sxx v2
Trinity d3.5
Revtech batteries
Spektrum radio
#229
+1 on ditching the scales. I used scales for about 3 months, then pitched them so the temptation would never get me again.
#230
i love scales but thats me i use them to set a car up for the first time and i move electronics out to find the best cross weight so tweaking the car will be a ton easier and the car will drive way smoother .
i can send you pictures of my car if you want but i did stick a 1/4 ounce of weight on battery as far back on right side as i could
#231
.... what Dumper says. Left to right balance should be the most important thing. Use front to aft balance for handling. I use a simple triangular ruler, line it up on the pin holes on the chassis, if the antenna is sticks straight up as you lightly hold the tire...you're good! It will be apparent if one side is heavy or not. Shift you electronics side to side to get it right. If you are curious about fore/aft weight bias, just mark the chassis where it balances, measure to the rear axle, divide by 204mm (wheel base of the car). You might come up with something like .45, that is 45% from the rear axle. That will be a 55/45 weight bias. Nobody uses this, so no point in referencing it. It's only handy when you build a new car and you simply want to know.
Brian
Brian
#232
thanks everyone
i like Slapmaster6000 idea it is simple. now i have to go get a triangle ruler.i will ditch the scales.
was getting ready to ask my lhs to order the zeppen scales
#233
proper ride height
where do measure from, the placement of the ride height gages if someone can take pictures
#235
Ok so i goofed i ordered rear ride height spacers and this car doesnt use those .....its my first venture into 12 scale.....anyways if anybody needs these for an older model let me know.
#236
Who here has dealt with the tq booster website and how long does it take to get your shipping quote after you make the purchase?,,,im coming up on 24 hours and still no email from the company?
#237
Team EAM
http://www.hobbyking.com/hobbyking/s...idProduct=7884
EA
#238
I got the TQ booster last year and I will say of all 4 boosters I have tried I like it the best. Super small. Voltage stays stable throughout the entire pack.
I have done some load testing and with pulling 30A steady no drop in performance from the booster.
Very little wasted power.
I had the hobbyking one which worked great but the voltage ranged from 5.6V full charge of the pack to 4.7V at the end of a 8 min run using 3300mah from a 4600 Pack
#239
I had two of these. Their regulation was okay at a little over 5V, but neither had anywhere near the advertised 1A output current. The worst was good for about 600mA before falling out of regulation, when running from 4.2V. But they still worked fine with the servos and ESCs I was using.
#240
I got tired of dealing with boosters and got a VTX1 ESC instead
