Team CRC Xti 1/12th Scale!! >
Like Tree221Likes
    Hide Wikipost
Old 03-02-2021, 05:42 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team CRC Xti 1/12th Scale!!
Last edit by: tobamiester
Old 12-17-2012, 07:27 PM
  #796
Default My XTI is Loosing the Back end!!
Help!!
My XTI is handling amazingly well with one exception, at the end of the straight we have a tight 180 corner and sometimes my car will just slide out as I enter the corner? My car is pretty much stock and were running 17.5 blinky on a very tight track. Grey low rears and chrome fronts both safety glued. I'm running 10,000 in the tubes, white side springs and white center spring and 50 front springs.
I'm using sticky finger traction compound with full treatment on the rear and about a 1/4 of the inside of the front tires. I tried a gold center spring that I thought would be softer and that didn't seem to help in fact it might have been a touch worse?
Any help would be greatly appreciated, thanks in advance..
Bob
Bobinmt is offline
Old 12-17-2012, 07:58 PM
  #797
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by andrewdoherty
Yep and yep. You're both correct.
Many thanks....
bvoltz is offline
Old 12-17-2012, 08:02 PM
  #798
bvoltz's Avatar
Originally Posted by Bobinmt
Help!!
Bob
Wait for the experts, but my first suggestion would be to increase the oil in the tubes... I would also go up on the center spring. I'm running Andrew Knapp's setup and it is really good, listed below:
Crc xti inline
.55 front spring
.404 king pin length
5 degree caster
.5 degree camber
Crc black center spring
30wt oil in center shock
2mm pod.droop
3.5mm ride height. Front , center and rear.
Magenta front tire
pink rear tire
blue side springs just touching
20000 dampner tube lube
Protoform amr
bvoltz is offline
Old 12-17-2012, 08:06 PM
  #799
3D-Seth's Avatar
Trader Rating: 36 (100%+)
Help!!
Bob
Bob,
I'm no expert by any means but at our local track I had a similar issue.
I'm running it pretty much box stock but I did change to 0 degree caster blocks, and I'm running Yellow Rears/Black fronts, green center spring.
Switching from Chrome fronts and Grey Low rears to Black fronts and Yellow rears seemed to keep my car from doing that. I'm using SXT traction compound here, and doing full rears and 3/4 inside on the fronts. So far it seems (to me anyway) that tires are about 85% of the overall setup of the car. Give the above set a try.
3D-Seth is offline
Old 12-19-2012, 08:27 PM
  #800
bvoltz's Avatar
Originally Posted by 303slowdown
Pod droop is very important. It effects how much weight gets transfered to the front of the car off power. More droop = more weight transfer. I measure ride height at front of pod then pull where shock attaches to pod till suspension locks out and re measure, that # is your droop.
Ok... Here is what I have, let me know if I have a reasonable understanding...
I can pick the center of the car 2mm before the tires come off the setup board.
I have RH front 3.5, center 3mm and 3.5 Rear.
Before I made the above adjustments I had 4mm and the car was flat... 3.5mm at all 3 points....
I'm trying to learn....
bvoltz is offline
Old 12-19-2012, 09:00 PM
  #801
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Pod angle, and chassis sag, 2 different things that work together
Have a quick read HERE
RedBullFiXX is offline
Old 12-19-2012, 09:21 PM
  #802
303slowdown's Avatar
Trader Rating: 24 (100%+)
I would raise your center to 3.5, then you will have 1.5mm of droop. Try that first then try it with the .5mm of chassis sag and see if you notice a difference. I dont run crc cars but i normaly run 1.5mm of droop in the slower classes and 1mm in mod. You will have to do some testing to see what works for you.
303slowdown is offline
Old 12-19-2012, 09:26 PM
  #803
bvoltz's Avatar
Thanks. I will give that a try...
bvoltz is offline
Old 12-19-2012, 09:28 PM
  #804
bvoltz's Avatar
I did many times... I just wanted to verify I go it... the text..... As I'm a newbie with 1/12th, I was just checking with you fine folk here if I did it correctly, so I change the verbage to show my understanding, could be + or -....
bvoltz is offline
Old 12-19-2012, 09:32 PM
  #805
Cool
Learning all the new stuff is the most fun, with mostly low expectations at first
After that it's just applying what you know
And later the frustration of expert drivers always wheeling cars around faster we can
Old 12-19-2012, 09:37 PM
  #806
bvoltz's Avatar
Cool
May I ask...
Running a shorter shock ball end to the longer one, (yes I would have to move the pivot ball 1 hole) what will do this do for the car? if anything....
bvoltz is offline
Old 12-19-2012, 09:44 PM
  #807
May I ask...
That would be a great question for Dumper, or another CRC team driver
Having never owned or driven a CRC, I could not give accurate advice on that
Old 12-19-2012, 10:34 PM
  #808
Who makes that front brace that goes across the top of the caster blocks? Just got me an XTI and I want to make sure and order one Thanks
InspGadgt is offline
Old 12-19-2012, 10:37 PM
  #809
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
CRC
andrewdoherty is offline
Old 12-20-2012, 12:36 AM
  #810
Robert_K's Avatar
May I ask...
Correct me if I'm wrong, but as I understand this changes the angle of the center shock and therefor mostly the amount of rotation (midcorner) steering. I thought it was like, a more straight (horizontal) demper give a little more rotation midcorner, but takes a way a bit steering at corner entry.
Regards Robert
Robert_K is offline
