YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 01-07-2015, 04:09 AM
  #5191
Lonestar's Avatar
Trader Rating: 14 (100%+)
Guys
I asked a few weeks ago but didn't really get an answer I understood
What is it with the Oring: 1 or 2 field in the setup sheets? Most have two... how do you fit two orings in the cartridge? And why vs. the stock one?
Thanks!
Paul
Lonestar is offline
Old 01-07-2015, 04:44 AM
  #5192
EDWARD2003's Avatar
I'm all about promoting peoples products.
EDWARD2003 is offline
Old 01-07-2015, 08:28 AM
  #5193
Originally Posted by Lonestar
Guys
Thanks!
Paul
You use a smaller spacer in the lower part of the shock body.
Yokomo part number BD-S2W
ATXPro4 is offline
Old 01-07-2015, 10:59 AM
  #5194
Jamesalex's Avatar
Hi, currently looking over a mates bd7, running 13.5 blinky. I was wondering if anyone could advise me what cam settings the front and rear belts should be on the kit is a month old bd7 14 black.
Regards
James
Jamesalex is offline
Old 01-07-2015, 11:02 AM
  #5195
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Regards
James
Can't provide a specific number
What I do is set the belt so it has some tension (not tight), then back off 1 click
Make sure chassis is perfectly flat before you do this
RedBullFiXX is offline
Old 01-07-2015, 10:51 PM
  #5196
Jamesalex's Avatar
Many thanks, I will work on that basis.
Old 01-08-2015, 11:15 AM
  #5197
reg
When I built mine,the stage when the belts are on early in the build,on the diff setting set to low and in the middle,it pulls the front of the chassis off the class plate,one notch looser and it was fine,probably after it's been run the belts stretch so it might not happen,just something to not though as you could build the car with a tweak
reg is offline
Old 01-08-2015, 03:13 PM
  #5198
Hi
My gear diff is leaking from the casing in my new 2015. It hasn't even run yet. What trick did i miss? Did you put some black grease around the o ring and gasket to seal it all up?
Marc
marcvanderzon is offline
Old 01-08-2015, 04:10 PM
  #5199
Jochim_18's Avatar
Originally Posted by marcvanderzon
Hi
Marc
Never had issues with mine leaking other than the gears need to be sanded down to make the gear diff butter smooth.
Jochim_18 is offline
Old 01-08-2015, 05:17 PM
  #5200
EDWARD2003's Avatar
Need some assistance with gearing a 13.5 blinky. What's a good range to work within? First time running 13.5 indoor carpet.
Old 01-08-2015, 08:51 PM
  #5201
Hi
Marc
Are you sure diff half screws are all the way in
Also, is it possible you have over filled the diff ?
Had to remove .1mm from the backside of the gears on a 15' diff I built, but it doesn't leak at all, super smooth
Depends on motor, setup, track size/grip
I run anywhere from 4.0 to 5.0
LRP X20 30*
Old 01-09-2015, 01:31 AM
  #5202
Lonestar's Avatar
Thumbs up
Thank you, very useful
what is the impact on the shock performance vs stock one o-ring? t
Thanks!
Lonestar is offline
Old 01-09-2015, 01:32 AM
  #5203
Lonestar's Avatar
Thumbs up
uh-oh - sanding diff gears... didn't do it Which ones, planetary (the big ones) or satellites? Thanks!
Lonestar is offline
Old 01-09-2015, 07:41 AM
  #5204
Trader Rating: 20 (100%+)
Thanks!
With the double o-ring it is easier to set consistent rebound.
LloydLoar is offline
Old 01-09-2015, 04:48 PM
  #5205
Thanks for the input. I rebuilt the diff with some magic black grease. Lets see if it still leaks.
