YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 09-23-2012, 12:46 PM
  #346
NolanP's Avatar
The car is a lot different than the Xray. I find that with this car you have to let the car come around. With my Xray I had to drive the car very hard to be fast. This car not so much. It was 58 degrees out and the asphalt was very cold I was running a really basic setup. I found one thing that I have already modified to get better grip in the rear. On the turn buckle in the rear I switched to an open end on the outside by the wheel I added a 3mm shim to raise it up. I kept the inside at the normal level. They were at the wider setting.
I was running a 4.5 in mod boosted and the car was very very fast. I will be switching to carpet over the next few weeks. I will get something setup and update everyone as things progress. Using the stock parts from the kit I have gone though a front carrier and rear carrier. The car is a lot more fragile than the Xray/AE. So make sure you order spares. As well make sure that you battery holder as well if you order a kit. I have all the graphite stuff of order for carpet season and will go from there. So if you get annoyed by replacing a part here or there do not buy this car. If you are ok with changing a part here or there and you want something super smooth to drive its good.
NolanP is offline
Old 09-23-2012, 02:32 PM
  #347
MikeO's Avatar
Anybody have any classic Yokomo track banners around not being used in the USA? Paypal ready!
MikeO is offline
Old 09-23-2012, 02:33 PM
  #348
For anyone looking for spurs that fit, try RW Racing spurs for a TOP Photon, they fit perfectly
chris_dono is offline
Old 09-23-2012, 07:41 PM
  #349
kschu's Avatar
Trader Rating: 16 (100%+)
Originally Posted by mikeygar
congrats KS!!! did you build the car with graphite parts or did you use the kit supplied plastic? indoor/outdoor asphalt?
i use everything standard. Its already good enough..maybe on high traction condition, graphite parts will be better
kschu is offline
Old 09-23-2012, 08:58 PM
  #350
vabroom's Avatar
Top uses Kimbrough spurs.
vabroom is offline
Old 09-24-2012, 09:45 AM
  #351
Here is my basic Setup for high grip carpet! Maybe raise the rollcenter with 0,5mm shims at the innerside all around if the car is to planted! ;-)
Or try 500cst oil in the shocks ;-)
Attached Thumbnails YOKOMO Touring Car BD-7-starting-setup-carpet-bd7-page-001.jpg
Philipp1990 is offline
Old 09-24-2012, 10:10 AM
  #352
B00t13g's Avatar
To use two o rings in the shocks do you just put the thin bushing in the bottom and put two of the good o rings on top? Why is two better? Also are the stock pistons 3x1.1 or 3x1?
B00t13g is offline
Old 09-24-2012, 10:33 AM
  #353
Hey,
you must use this O-Rings:
http://www.fast-webshop.com/yokomo-b...h-Grade-O-Ring
with this thin collar:
http://www.fast-webshop.com/yokomo-b...ng-Coller-Thin
the movement of the shock-shaft will be more smooth and free! ;-)
And if you want 1,1mm shock-pistons, you must drill a 1,1mm hole in the 1mm original shock pistons!
I compared the original shock with this modified shock (as the teamdrivers run it), much smoother suspension!
Old 09-24-2012, 12:17 PM
  #354
B00t13g's Avatar
Was I correct of how you place them? Thin collar at the bottom then two o rings on too of that?
B00t13g is offline
Old 09-24-2012, 12:55 PM
  #355
Yes this is correct!
Greez from Germany!
Old 09-24-2012, 01:46 PM
  #356
Yes, that's why i said RW Racing FOR a TOP Photon....
Old 09-24-2012, 08:19 PM
  #357
B00t13g's Avatar
Regarding the diff height, is the low setting with the thick side pointed up or down? And what will this do?
B00t13g is offline
Old 09-24-2012, 10:02 PM
  #358
You have to point the thick side up if you want to run the diff height low! ;-)
That will give the car a lower center of weight and i think you should always take the center of weight as low as possible!!! And the Diff and Spool movement will affect the driving of the car if they sit higher!!!
Old 09-24-2012, 11:08 PM
  #359
B00t13g's Avatar
Max teeth is around 147. 99/48 was as much as I could fit today. I'm really loving this car.
B00t13g is offline
Old 09-24-2012, 11:14 PM
  #360
Stilo's Avatar
Actually from what I´ve understanded, diff height affects more through the angle of the driveshafts. Driveshafts always try to straighten and the more you have upward angle on the bone towards wheel, the more driveshafts push the suspension down to the ground adding grip. So if you run diffs in up position, you have less on power grip, but also less chassis movement regarding to your throttle input.
Stilo is offline
