Old 11-13-2008, 02:52 PM   #8641
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
yeah im trying to. just have not been able to race due to Financial reasons since reedy
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 11-13-2008, 02:52 PM   #8642
They look like new wishbones and pins/ mounts....
Bryan D is offline   Reply With Quote
Old 11-13-2008, 03:00 PM   #8643
STLNLST's Avatar
Trader Rating: 21 (100%+)
I hear ya there. I haven't really ventured out too much myself. We have a nice new carpet track that's having their grand opening race on the 22nd. I will be at that one trying to get my groove back...
STLNLST is offline   Reply With Quote
Old 11-13-2008, 03:28 PM   #8644
Matt Howard's Avatar
Coming summer 2009 "Tyler Perry presents, How Stlnlst got his groove back"
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-13-2008, 04:08 PM   #8645
Francis M.'s Avatar
Anyone have a pic of Naoto, Grainger, and Hofer's cars?
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 11-14-2008, 02:14 AM   #8646
capellone24's Avatar
grainger's car?
capellone24 is offline   Reply With Quote
Old 11-14-2008, 04:08 AM   #8647
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i dun think tat is chris grainer car.....got korea flag on d chassis....
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-14-2008, 04:15 AM   #8648
wide_mouth_frog's Avatar
all the pit gear is not in his colours either... some Korean driver I assume
Team Wave - absdesigns.co.uk - Selections RC
wide_mouth_frog is offline   Reply With Quote
Old 11-14-2008, 04:23 AM   #8649
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
This is a picture of martin in the pits, it is hard to see the car, but it looks the same as masmi's if not similar.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 11-14-2008, 10:55 AM   #8650
SammyZ's Avatar
Trader Rating: 138 (100%+)
nice pictures guys! redrc.net? well where can i get that yokomo pit mat?!
Oh and look Hoffer is running suzuki alloy rear hub carriers!
SammyZ is offline   Reply With Quote
Old 11-18-2008, 11:27 AM   #8651
Hello All,
Right been running my BD grainger for the past couple of weeks and am loving it really. However im have a few problems with the steering arms stripping out all the time. Ive read somewhere that i can convert to Hpi/HB parts on the front end to bullet proof the car a bit more. Does anyone have all the part numbers i need? (suspose the driveshafts will have to change to) Also what are the ball cups that massami used on his car during the worlds, and which ones did he use on the steering arms to the steering rack as mine keep popping off at silly times.
Sorry for all the questions
Craig
Slick990 is offline   Reply With Quote
Old 11-18-2008, 12:15 PM   #8652
JasonC's Avatar
if your striping the steering knuckle ( or as some say the sterring chub...lol or carrier)
im not sure what comes standerd on the grainger edition. if you use the BDM lower king pin ( part # Sd414TA) and the upper king pin from the Bx ( part # bx-414kb) you will have to shave a few threads off the 414kb if your running the steering knuckle in the upper position. you will also need the off road ball cups ( part # zc-207hd), i also recomend switching all of your ball studs to the off road ball studs, this way you can use a 2mm driver to remove the ball studs with our taking the ball cups off.
Old 11-18-2008, 02:36 PM   #8653
The grainger uses SD-414 on the steering knuckle (arm, hub etc ) I lost 2 of the bottom kingpins this weekend through them just stripping straight out of the knuckles (pt...sd-415s)
I had a look at using the HB c-hubs and knuckles but the bearings are thicker so would need a longer axle....the other idea is to try a Tc5 knuckle like massami used as i think the bearings are the same.
Old 11-18-2008, 02:45 PM   #8654
JasonC's Avatar
since your striping the bottom out just get part # part # Sd414TA this will solve your problems, wrost case senaro when using this part you can use a longer scew to have more threads in the steering knuckle.
Old 11-18-2008, 02:57 PM   #8655
JasonC's Avatar
actuall you use the same bearings, you just have to use the bearing spacer that is supplied with the BDM alum Universials. ( you are correct the TC5 bearings are the same.) i have tried to use the TC5 knuckles but found little to no reason to use them over the yokomo ones
or if you really want to use the HB knuckles you can use the axles and bearings for the HB/hpi car ( pro4 or cyclone cvd style) and use any of the following axle shafts ( Tir racing, corally/rdx, or rayspeed. that i know of
Yokomo MR4TC CGM wyl03 Australia For Sale/Trade 0 06-26-2007 04:39 PM
yokomo mr4tc pro racer57 R/C Items: For Sale/Trade 3 10-07-2006 02:34 AM
Looking for Yokomo MR4TC BD1 yyhayyim R/C Items: Wanted to Buy 1 08-24-2006 07:07 PM
yokomo mr4tc i730 R/C Items: For Sale/Trade 0 07-20-2005 02:51 PM
WTB: Yokomo MR4TC SD SSG! DOMOisCOOL R/C Items: Wanted to Buy 2 03-06-2004 08:31 PM
