Yokomo MR4TC-BD
#7668
Does anybody have a dialed setup for foams on carpet. I will be using 19t and the yokomo hard chassis???
#7670
#7672
Hey John,
Can you show or explain how Chris fits the yokomo inline knuckle into the HPI/Cyclone C hub??
#7674
hi all , i have broke my front worlds wishbones on my bd if i run this part (sd-300fo5) with the standed wishbones will it work the same as the worlds wishbones?
http://www.microtechracing.com//prod...&cat=SD+%2F+BD
thanks mark
thanks mark
#7675
thanks mark
thanks mark
Best Wishes
Scott
#7676
No, that part gives inboard toe out by moving the rear of the hingepins closer together. The Worlds wishbones are shorter, achieved my moving the hinge pin pivot down the arm. You could use a pair of std arms to get by but I am sure some shops should have worlds arms in stock.
Best Wishes
Scott
Best Wishes
Scott
#7678
re: arms (I dont know if you are using an SDW setup. If thats the case, go with it again its better according to some other racers who tried it before. although, the same effect of going with the SDW setup can be achieved with todays modifications about the BD, to start off try Chris Grainger's asphalt setup.. )
...scroll back for more BD setups. Cant wait for some R&D's for the BD. haha
#7680
should i be running std front arms on carpet with rubber tyres rather than the worlds arms? Ive been struggling to stop traction roll could they be causing it?
