Yokomo MR4TC-BD
Old 02-05-2007, 11:49 PM
  #6826
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default dan
dan
I have a spare standard chassis, top and lower deck.
Keep the servo stays it's easier to adjust with the different types of servos.
olhipster1 is offline
Old 02-06-2007, 12:46 AM
  #6827
29TC's Avatar
What pinion and spur combinations to use for a hot mod motor, 48pitch?
Currently using 18t pinion and 84T spur for Orion V2 8x2. I just got a 7x1 Cobalt. Smallest pinion is 17T and biggest spur that will fit in the BD, I think is 84T.
What combination are you guys running? Any suggestions?
By the way I run on a track with pretty long straights and very twisty intermediate sections.
Thanks.
29TC is offline
Old 02-06-2007, 08:39 AM
  #6828
Originally Posted by olhipster1
dan
I was going to keep the inner one but lose the outer one as its tricky to get that miled out. so if you put servo tape on the underneath of the servo and use the inner mounting point. I used to do this without any problems. I have found an old chassis that i will check it to.
Dan Hughes is offline
Old 02-06-2007, 09:51 AM
  #6829
tantalus007's Avatar
Trader Rating: 17 (100%+)
ive seen a few drivers setup sheets having set the anti roll bars at the lower setting position, how do they do that??? Could anybody post some pics or give a detailed explanation on how to do that??? Thanks…
tantalus007 is offline
Old 02-06-2007, 06:19 PM
  #6830
curious mind's Avatar
follow-up on the querries...
hmmm very interesting... what are the effects of the low roll bar setting?
curious mind is offline
Old 02-06-2007, 06:51 PM
  #6831
coons88's Avatar
The standard roll-bar setup is the 'lower' position. The 'upper' position is when the roll bar goes the other way and goes up over the top deck.
Sort of like this
Thats how I understand it to be anyway, and I don't know how you mount the roll bar like that, or why you would do it. But I have seen a SD been run with the roll bars like that.
coons88 is offline
Old 02-07-2007, 01:58 AM
  #6832
Hi All
I plan top post some pics of the CGM steering mod this week and explain what it does, there seem to be many questions about at the moment about various parts of the BD, I don't get on here as much as I would like, so please post some Questions for me over the next day or 2 and I will try to answer as many as possible
To reply to the Question above, the Kit roll bar is the "lower" roll bar the above one is one that goes over the top deck from the old MR4. We never use this any more.
Chris
Chris Grainger is offline
Old 02-07-2007, 08:29 AM
  #6833
coons88, chris: thanks for all your replies, guess i just have to change to a thicker stab bar...
Originally Posted by Chris Grainger
Hi All
Chris
i hope you could also post pics of the c-hubs and front knuckle arms to see the mods that youve made...
Old 02-07-2007, 09:22 AM
  #6834
Hey MR4-TC BD Guys; I was looking at the Masami Special on the Yokomo site and I`ve seen markings(lines) on the Lower Bulkhead.
-What does those markings(lines) mean?
I`m thinking about getting a Masami Special; it`s a nice looking kit.
-I can put the Electronics from My Pro 4 into the MR4-TC BD.
Take Care
GuyIsDamGood is offline
Old 02-07-2007, 09:36 AM
  #6835
Racingbod85's Avatar
Hi chris - thanks for offering to answer a few questions. if it's not a secret what piston/oil/springs were you using at the wars on sunday? i wish i could get my car that stable - think it's way too soft! i'm running std shocks and rayspeed springs, can you suggest a basic setup? plus was that a prototype topdeck you had on - maybe one we will see on the updated version? thanks AC
Racingbod85 is offline
Old 02-07-2007, 09:53 AM
  #6836
Anybody know where i can find the a yokomo fan mount? I saw it at the Yokomo table site at the Reedy race last year and never got around to getting one.
Alex Lopez is offline
Old 02-07-2007, 03:01 PM
  #6837
olhipster1's Avatar
Default MARKINGS
Guy,
I believe the markings on the lower bulkhead are to help adust the diff height I also use it to adjust the belt tension on both sides equally. hope I'm looking that correct markings. the markings are in both the rear and front bulkheads.
The BD masami is a great car my only suggestion would be to get an extra set of steel CVDs and immediately replace to front (leave the blues as spares for the rear).
And get a full set of springs, the corally spring set fit rather well.
AleX
I've been looking for the fan mount also for quite sometime, speedtech never has them in stock.
Old 02-07-2007, 03:10 PM
  #6838
Wayne1one's Avatar
Does speedtech ever have anything in stock
Wayne1one is offline
Old 02-07-2007, 03:19 PM
  #6839
JasonC's Avatar
Trader Rating: 120 (100%+)
Yokomo has them in stock.... part # sd-cfm $31.50
JasonC is offline
Old 02-07-2007, 03:23 PM
  #6840
JasonC's Avatar
olhipster1
the front and rear universals are diffrent... so you cant use the fronts in the rear.
JasonC is offline
