Yokomo MR4TC-BD
#6391
Originally Posted by MR JOLLY
PS; I love My BD
i`ve had JRXS,CYCLONE,SD,LCG (liked this car also), Xray 04.xray 05,evo 4, evo 5
BD i like alot
doeas any know where i can find the blue ALI Diff halves Yokomo make for the BD ?????
chris had some on he`s car ,can`t find them anywhere ,he was using the HARD chassis for BD aswell
BD i like alot
U can get ALI half's in gray.
ste.
#6392
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by tcfree
Not shure if the diff halfs are in production yet? i hav not herd so.
ste.
ste.
found them now ,thanks chris grainger for he`s help on sunday aswell (such a nice lad)
#6393
I use the outdrives for I guess 1 1/2 month now.
pretty good, even without blades. no excessive signs of wear (I'm drivin 3,5T Brushless in carpet)
#6394
yep they are
#6395
@Martin
can i put your mates link on the boards ???, you PM it to me & i`m not sure
#6396
Are the Bomber shock towers worth getting (the one with loads of muti holes on )
#6397
We have a problem with newly installed Yokomo hardened universals.
The thinner pin in the joint (rear wheel) keeps coming out al the time.
I wonder if other people have had the same happen.
Can anyone suggest a fix to this? I would hate to just discard new, rather expensive and hard to get parts.
#6398
#6399
#6400
Can you get ally or steel pulleys? I cant imagine they would wear great but i melted two diffs
#6401
Originally Posted by AngryAsian
Jarkko - you're not the only one. My friend runs a yokomo, and aprat from the steering kingpins that always work loose, his CVD pins always eject. Either fully, or partially. He loctites his, and even cuts a small notch(dremel) in the pin for the grub-screw to "lock" it in place. Seems to help.
#6402
#6403
yes it's ok putting his link up
#6404
Originally Posted by Racingbod85
I did that exact thing to my brand new diff 1st round CW on sunday! had to cut the diff balls out with a knife, but they were fine being carbide!
The rings were molded into the outdrives too. The new one i built is nice and tight so it should not happen again
#6405
Since the SD this has always been an issue. Ive tried different driveshafts etc. Best way i found. by mistake/anger was to just tighten them up so tight until it rounds off the hex! on the grub screw not the wrench :P Not had any issues since.
http://static.flickr.com/118/309479663_7eb34298ac_o.jpg
I suppose making a hole for a grub screw might work. I'll try that.
