Yokomo MR4TC-BD
#1486
A hold down like the Mission 2 has would be ideal. It doesn't bow up in the middle and it holds the cells better than a flat piece of graphite. I wonder if it would fit.
#1487
Originally posted by Geppetto
Chrissy C: I'll look at using the SD battery hold down. I'm ok with drilling a hole.
Turtlemaster. Although, I haven't tried it yet, I have considered using the SD battery hold down. I hadn't thought to use it up-side-down, though.
The SD battery hold down just doesn't look as pretty as the BD carbon fiber plate.
#1488
R/C Tech Elite Member
Got back from a fun day of spool/diff testing (man I hate anything that isnt a 1 way!) but I got the car working pretty well. I thought up a few changes that I'm going to make to the car to give it a bit more steering, but it seemed to do alright.
When using brakes, the JB Weld just doesnt hold up, it came loose on my front and center 1 ways, I put a set screw on my center 1 way but it just didnt seem to hold well either. I tried a front diff, and it did good on the tighter parts of the track, but on the high speed sweeper I couldnt use much throttle at all. I also made a plastic spool using regular outdrives, and Losi sandpaper diff rings for spools, this was actually the best, gave the most steering of the 3 front variations (comparing to the locked 1 way before it started to slip)
Pops - Good seeing you, cant wait for Reedy, should have a dialed setup by then.
F.D. - Shim up your rear inner ballstuds 2mm and leave the fronts without the shim, gets the car rotating really well in the tight corners, but still holds good cornerspeed through the fast stuff.
#1490
did anyone else had problems with the lay shaft when using the center oneway? the center 1way gear ate away at the lay shaft; thereby causing it to freewheel on power...
#1493
Dropping the link will give different bump steer characteristics but i am not sure if this is whay he has done it.
Also if you look he is using the old style wishbones, probably the graphite ones and he has cut all the camber mount points off the front hubs as he is using the kingpin point.
#1496
Re: Bump Steer???
So you are saying that dropping the link, changes the bump steer. What exactly is bump steer?
I did notice that he cut off the extra mounting points on the C carrier. I didn't recognize the arms as the older ones.
#1497
Another question???
Is it ok to clean/degrease the one-way diff on the BD. I notice that my front wheels don't spin very freely. At first I thought the problem was the bearing, but upon closer inspection, I found that the outdrives aren't spinning freely.
If I can clean the one-way out, what type of lubricant should I use to re-lube it?
#1498
Matt, do you know a date when a locked pulley will be released. I want to get a BD but i will not be as fast with it with a centre 1 way.
#1499
Re: Another question???
or use X-rays one-way lube.
#1500
