Yokomo MR4TC-BD
#1518
Originally posted by Randy Caster
Just checked out Speedtech's site and the car did have it's own set of aluminum universals. I wasnt aware that it used different suspension, but what kind of arm mounts were used?
#1519
They are the same ones Masami uses.
#1521
Originally posted by Dan Hughes
Matt, do you know a date when a locked pulley will be released. I want to get a BD but i will not be as fast with it with a centre 1 way.
#1522
The BD arms are a heavy duty material, it's really strong, but it does flex. You can use the SD-008G arms on the car with no problems, but the new arms SD-008HG are floating around, I've seen them, just not in any big numbers yet.
#1523
Originally posted by Matt Howard
The SDW used a shorter front arm with a wider front suspension mount. The universals used will fit on a regular SD or BD but since they're all aluminum, including the axle, they're not very durable.
#1524
I have Masami's and Pumpler's setup from the LRP race last weekend but it's too big for me to put it on here. If anyone wants it just email me at [email protected] Maybe you'll have better luck posting it on here
#1527
I got my SD-008HG from R10 and StormerHobbies. Had to have something as a spare or backup. Could have used the old SD arms as spares. But if I'm not mistaken, the shock mounting holes are aligned different than the H and HG arms.
#1529
Yes I see now. You are correct. The H and HG front arms only include the 1st 2 holes. And the rears only include the last 3 holes. I was aligning them up wrong hehe... My bad. I don't have my SD anymore to compare..
