Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 10-19-2008, 11:54 AM
  #14191
BradBaker's Avatar
is this a good car for touring??
BradBaker is offline
Old 10-19-2008, 02:58 PM
  #14192
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Without a doubt, yes.
Syber Serulean is offline
Old 10-19-2008, 03:12 PM
  #14193
This is what they look like with all the hop ups.
Lazer Guy is offline
Old 10-19-2008, 04:07 PM
  #14194
KHoff7's Avatar
Originally Posted by cyclone speed
do you mean straighter shock position or stiffer spring.
What im looking for is a bit more on power steering but not at full speed, only at half speed or slower.
Im curently running pink front and silver rear
Either will help, I generally like my rear shocks more layed down so the car is smoother in the rear and not as bitey and reactive as more stood up shocks would be. Go experiment with the changes ie stiffer spring or more stood up shocks in the rear for on power steering. Also you can take out some front droop therefore not allowing the chassis to kick back in the front as much and keeping weight on the front tires under acceleration, this will also make the car a little quicker to change direction in the front making it roll less in the front thought chicanes.
The main thing to do is go try the changes on your car at the track and see what best fits your driving style.
KHoff7 is offline
Old 10-19-2008, 05:06 PM
  #14195
LOSI123's Avatar
Trader Rating: 63 (100%+)
Anyone that hasnt already put cooling on the motor and is after the best and cheapest option, all you need is a small metal bracket drill 2 holes and get a 5 volt dc 40mm fan(from ebay), ohh and get the flat carbon middle deck.
and a servo extension cable or an old servo plug & lead, so as to plug it in.
As long as you have any spare slot in your reciever and your esc outputs 6 volt, it will cool really well.
cheers
Attached Thumbnails Hot Bodies Cyclone-cyclone3.jpg   Hot Bodies Cyclone-cyclone.jpg   Hot Bodies Cyclone-cyclone2.jpg
LOSI123 is offline
Old 10-20-2008, 02:28 AM
  #14196
Hi all,
Since here we look to be changing to lipo, wich lipo fit to the car without any dremel help?
Thanks in advance.
jorgesimes is offline
Old 10-20-2008, 03:19 AM
  #14197
cyclone speed's Avatar
hi , when would people go to a higher or lower RC.
Is it when the track is tight or open or is it when the grip is differente.
Or how would people know when to change the shock oil or spring or piston.
Thanks in advance
cyclone speed is offline
Old 10-20-2008, 06:45 AM
  #14198
Default Dogbones
Ok, apologies if this has already been asked.
I have the new Cyclone TC and run the fixed spool on rubber tires on carpet. I keep breaking the front drive shafts at the hub end.
Can i use the earlier steel 44mm version of dogbone 60116 or 61043 in the TC?
Cheers
blueskieshlg is offline
Old 10-20-2008, 10:24 AM
  #14199
Originally Posted by jorgesimes
Hi all,
Thanks in advance.
Originally Posted by Syber Serulean
and for lipos in the Cyclone...
ive used Yeah Racing 3200s and 4000s in there with no problems as well as Orion 3400s and 3600s.
Old 10-20-2008, 11:25 AM
  #14200
RC MARKET's Avatar
Yes !
RC MARKET is offline
Old 10-20-2008, 01:29 PM
  #14201
Cheers
That is kind of strange, they're not as resistible as we wish, but breaking it's kind of diferent. I would go to this check list:
1. Steering Rate
2. After each run check the screw that holds the pin and always mount it with some thread lock
3. Check if you don't have to much droop.
I think for now its all, but help is always welcome.
However i think they fit perfect.
Old 10-20-2008, 02:20 PM
  #14202
ShaunMac's Avatar
Hi all,
Thanks in advance.
There are more Lipos out there that will fit. These are just a few that I knew off the top of my head.
SMC 4000, Trinity IP3800, Orion 3800 and lower, Core RC 3250
ShaunMac is offline
Old 10-20-2008, 02:39 PM
  #14203
STLNLST's Avatar
Trader Rating: 32 (100%+)
The car is almost ready for the regionals. We have been testing for the last two weeks and made some driving errors that gave the only MI3 driver a false sense of confidence (even though my boy lapped him at the KO) so come this weekend it's on. I feel this car is either gonna TQ and win or come off broken... The last two weeks have been a ton of fun and I expect nothing less from this race. 13.5 has been so much fun that the remaining mods I have will be up for sale right after the regionals along with the rest of my Futaba equipment. If interested pm me. Man I love this car
STLNLST is offline
Old 10-20-2008, 02:49 PM
  #14204
BillyCaldwell's Avatar
Good luck at regionals Clint. Pm me with that Futaba stuff you have please.
BillyCaldwell is offline
Old 10-20-2008, 04:02 PM
  #14205
STLNLST's Avatar
Thanks and check your PM
STLNLST is offline
