Hot Bodies Cyclone
Gentleman81
yes there are currenlty 5 models out.
1. Black cylcone Hara edition
2. Surikarn "limited edition" blue components not purple. hard to find.discontinued
3. Cyclone S model, lower end edtion.. all plastic.
4. Moorespeed tons of Purple Bling!! discontinued because of newer car. Expensive.
5. Cyclone TC the newest model out. Less expensive, not as much bling but
but better upgraded components.
I live in NoVa. raced both my cars at the HPI race @301. Setups are easy to find to get the car to work, car drives easy!! Parts are reasonably priced.
Currently racing at THE TRACK(MIMIs).. LMK if you need more info. I currently own 3 out of the 5 models... Chris @ 301 has seen my cars run, Vince drove my other car to see what electric was about.
Arv.
Arv.
you forgot the Hara edition so that would be 6
Trader Rating: 20 (100%+)
yah.. forgot. JUST PICK YOUR "BLING" they all perform well.
Gentleman81
Arv.
Arv.
thanks man, that was everything i needed.
i will be starting from scratch with electric. but i wanna have the model i can grow on, and afford.
Hey fellas I have a Cyclone TC for sale if interested. Lots of extra parts. Ran car on asphalt so chassis has a few scratches. New bearings all the way around. Have great set up on it really easy to drive. Have the box and manulals as well. $300.00 Pm me if intereted. Also have a Novak brushless speedo to go with as well.
about those Xray U-joint style axles...someone else posted this...
"the dogbone will probably be a little too short - the cyclone's are 50.3mm long...
Now if you could swap dogbones, you might be onto something"
Gentleman81
Arv.
Arv.
If the cyclone ones are 50.3mm than the 52mm xray bones will fit no problem. I am running pro4 axles in my cyclone with no issue and they are at least 3mm longer than the cyclone axles
for you all what are the negative points of cyclone and what it could have improved.
Here in Brazil, I continue knowing of people who do not like the diff.
Trader Rating: 23 (100%+)
-j
