Hot Bodies Cyclone
I ran a 4600kv (more then a 10.5=4200kv) on carpet so I left it in to try your setup and get my asphalt legs on again.
The 7700kv on paper is between the 4.5 and 5.5, I ran the 7700 all last year. On the track it runs with a good 4.5 when geared right. Both my Mamba max's have tremendous mid-band HP witch makes them unpredictable in TC's as stated by rcenut123. I run my low end up and it helps smooth out the mid-band. My 7700 will pull away from the 3.5's and 4.5's coming onto a strait but the 3.5's will pass me on the long straits.
STLNLST, what insert are you guys using the 36's? Thanks.
right now we are running the premounts from speedmind but when I glue up my own then it's all Hara inserts
If no shirt then some stickers???????????
I think I have that set up sheet but I,m not sure it's the one you are using.
which Hara inserts are you using? The medium or the firm, version 1 or version 2?
thanks
thanks
Where are people getting the hara inserts from?
I got all of mine over seas last year. I bought a ton of them and with us running mostly handout tire's (RIP RP30's) it took me a while to go through them. I do have to find me a new source for them.
Thank you
Has anyone managed to get a hold of the new arms?
Interested to see if the slightly softer rear shock position yields good results, as the HPI suspension is always firmer in the rear end.
The rear upright had toe-in problem !
I only use lipo and a 10.5 brushless. Where do you guy place weight to get your car legal? I have to add at least 300 grams to get my car up to 1525 grams. I have a soft pack SMC 4000 lipo soft pack and planning on getting a hard pack 4000 lipo.
longshot of a question...looking to try to get correct gearing with a 17.5 on my hara cyclone...
but i dont want to switch belts or pulleys or any of that jazz. Lookin at speedtech i can get a 87t spur (if you guys know where i can find smaller spurs that'll work on the cyclone lemme know) and 59+ tooth pinion gears. The huge ass pinions will definately be helpful on attaining the right gear ratio but will it be too big and hit the chassis? Would i have to buy that brushless motor mount kit? That thing is expensive :/
On the sides of the battery until it is balanced, you can also mount weights on top of the battery. When the weight is placed on the side it will give more leverage for balancing without having to add as much physical weight.
