Hot Bodies Cyclone
#9826
speaking of aluminum stuff i am selling my rear 0.5 degree hubs. almost new. here is the thread link:
http://rctech.net/forum/showthread.php?t=165157
#9827
great reading the whole thread through.
but i have a tire wear problem on my cyclone wce.
both front tires wear excessively on the inside (as in the attached picture).
i started with 1.5deg negative camber and went back to between 0.5 and 0.75 by now they still wear like this. the camber rise is on the lowest setting (hole1 in the topview).
what can be the problem here?
#9828
I wonder if they really add any efficiency...
They are like 36 tooth pulleys with every other tooth missing. It's the opposite of cutting every other tooth on the belt, except that you are not weakening the belt. I do not know about these pulleys being prone to skipping, but makes me curious.
Your 3racing 18t main pulley and the diff wide pitch pulleys will bring you down to 2.00 ratio if you can actually use them. Maybe the belts would be too loose using those parts and you had already given it a try.
Just a thought...
#9829
inside & out side same time to lose
#9830
Well I am having to move for my job and that means no more 4wd touring car racing and having to migrate to the 4wd electric buggy world.
If anyone is interested in a pretty nice Hot Bodies Cyclone Setup, here is my link:
http://www.rctech.net/forum/showthread.php?t=185581
#9831
#9832
Have you tried Tamiya's wide pitch diff pulleys for the TRF415?
Just a thought...
Just a thought...
#9833
What did you need to do to make the 501x diff fit better?
Would these work with a front one-way? ... or would too much material need to be removed?
#9834
having abit of gearing issues.....Needing to get a ratio of 8.1-8.2 and worked out what pinion i needed for the spur i had,But ended up too small,who knows of a spur/pinion combo that will work to get the gearing i need?
#9835
accumulated number of teeth on the gears should be larger then 134 for 64dp gears.
oh if you want to use 48dp the number should be greater then 102.
good luck
#9836
for the people interested in gearing numbers i made the following spreadsheet for the cyclone.
if the gearing will fit is shown in the table on the right which will turn green for a fitting set and red for something that will not mesh.
cyclone_gearing.xls
cyclone_gearing.xls
#9837
#9839
