Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 08-25-2007, 10:29 PM
  #9511
Trader Rating: 22 (100%+)
Originally Posted by barber
along with the 2.5 piviot block up front how much more toe do you guys run when you put it on the setup board and would it be pos or neg.running asphalt high speed track.
It depends if you want more inital steering or more mid corner steering.
Positive 0.5 to 1 will give more inital steering less mid corner \ /
Level,flat or | | balanced
Negative -0.5 will give more mid corner steering less inital / \
High speed track I would say try toe out (positive) first
bjspinner is offline
Old 08-26-2007, 05:44 PM
  #9512
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
can someone measure the distance from the outside hinge pin to the inside hinge pin on the a arms (center hole to center hole) and let me know
thanks Dave
Dave Bowser is offline
Old 08-26-2007, 07:48 PM
  #9513
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
thanks Dave
dave if you are trying to use the arms of the cyclone i believe they will work i gave a set of HB arms to raf at the last region race in kissimmee
Marcos.J is offline
Old 08-27-2007, 06:41 PM
  #9514
Cyclone racers I have a quick question, I am having problems with my rear tires wearing on the outside even with a 2.5 neg camber the tires still wear faster on the outside than the inside, on most of the TC cars I have race the wear is on the inside but the Cyclone wear on the outside, is there anyone that is having this wear problem? and if so what did you do to get it wearing on the inside? thank you.
Ramyuras is offline
Old 08-27-2007, 07:35 PM
  #9515
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Hmm thats wierd
I run 2 deg and the tires wear almost dead even on the whole tire
BlackedOutREVO is offline
Old 08-28-2007, 01:02 AM
  #9516
barber's Avatar
i run brushless and only use 2deg and tyres rear even,what setup at the rear do you have.
barber is offline
Old 08-28-2007, 05:54 AM
  #9517
I am using Jason Scherffler setup.
Ramyuras is offline
Old 08-28-2007, 08:58 AM
  #9518
padailey's Avatar
Mine in the rear seem to be doing the same thing. I'll have to keep a closer eye on it.
padailey is offline
Old 08-28-2007, 09:00 AM
  #9519
Core Creations's Avatar
Trader Rating: 108 (100%+)
I'm assuming this is with foams....I've used as much as 3-3.5 negative on the camber to keep the tires square.
Core Creations is offline
Old 08-28-2007, 09:07 AM
  #9520
I was thinking the same but with all that camber what do you think will happen to the handling of the car? I am using the BMI chassis I am thinking if that has anything to do with the issue at hand because before I went to the BMI chassis I didn't have that problem.
Ramyuras is offline
Old 08-28-2007, 09:32 AM
  #9521
TheCoolCanFanMan's Avatar
Hi Guys
I ran the Clone for the 1st time at the weekend in the KO in the UK. What a car, it goes exactly where you want it to go. I made 7th in the A, and came 8th overall 'AWSOME CAR'. Thanks to Stew Knoble, Elliott Harper and Paul Upton for the setup.
Cheers Malc TCCFM
TheCoolCanFanMan is offline
  #9522
No it doesn't hinder the performance at all. In fact the tires coning hinders the car much more.
Uusally you get that type of wear beacuse there is some play in the bearings (Normal). When you set the car up statically the camber is 2 or 2.5...but when the car is running and the play in the bearings comes into play you can have as little as maybe 1-1.5 neg camber.
Old 08-28-2007, 09:54 AM
  #9523
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
mine cone slighthy at 2.5 camber but our track is super tight and the rear is sliding around most of the corners I just retrue the tires after every 2 runs to keep them square
I thind it matters more on the track surface and layout more that anything else. because when i ran on a bigger track there was more coning but there was alot of high speed sweepers putting alot of side load on the tires and makin them roll over and compress
RaceAce701 is offline
Old 08-28-2007, 11:18 AM
  #9524
Default Carpet/Foam
Does anyone know or have a good starting point setup for carpet/foam tires ?
I just got a used Cyclone with the BMI chassis..
John Q is offline
Old 08-28-2007, 11:58 AM
  #9525
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by TheCoolCanFanMan
Hi Guys
Cheers Malc TCCFM
Big difference from our previous car eh Malc???? It's staggering how much simpler it is to our old cars and yet it performs soo much better .
2-Bad is offline
