Hot Bodies Cyclone
#8778
Super Moderator
Just wondering if the cyclone can have a fdr of about 3.6:1 for 540 racing & can it acept standard aftermarket spur gears?
also the spring rates for this car are they in coils? is there a conversion table to know what the rates are?
also do towers have the springs, if so what are they called, are they the pro liniar springs?
Hara Yellow 12.89lb/ 230g
Hara White 13.98lb/ 250g
Hara Black 15.11lb/ 270g
Hot Bodies Blue 15.3lb/ 273g
Hara Purple 16.24lb/ 290g
Hot Bodies Silver 16.9lb/ 302g
Hara Red 17.36lb/ 310g
Hot Bodies Pink 18.0lb/320g
Hot Bodies Gold 19.0lb/340g
Hot Bodies White 20.3lb/363g
Hot Bodies Yellow 21.7lb/388g
Hot Bodies Red 22.4lb/400g
#8779
Super Moderator
#8780
#8781
Size Colour Comp./ Ratio
#8783
guys how do u keep those blades that go on the end of the rear drive shaft pins from coming off? is there a fix besides dont hit crap?
#8785
Has anyone tryed the 3racing centre pulley with the 17t or 18t pulley?
is there any problem with front or rear belt tension being to tight?
reason is, I run 540 on a massive track and will be needing to lower the internal drive ratio of this car, i also need to stick with 48p gears as to save money on pinions.
i need to achieve FDR's very very low...
If i buy this car i will be purchasing that pulley with it.
(its a hard choice between the high end cars these days!!!)
#8786
Losi123 - the Pulleys work great and I have had not problem running them in 16, 17 or 18 set-ups, it does cahnge your final drive to a much better level. Belt tension is not an issue.
But the 3racing pulleys will not make the Final drive in the 3.6's , you divide the center pulley, by the diff pulleys to get your F-drive
Stock is 39/6=2.4375
39/17=2.294
39/18=2.166
39/17=2.294
39/18=2.166
#8788
What is a good site to buy cylcone parts from, besides tower?
#8789
#8790
I saw that Tower has two types of spools for the Cyclone
This one http://www2.towerhobbies.com/cgi-bin...?&I=LXNZF3&P=Z
And this one http://www2.towerhobbies.com/cgi-bin...?&I=LXNZD3&P=Z
Is one better than the other? Why make the same thing two different ways unless they offered benifits the other doesnt?
