Hot Bodies Cyclone
#8072
stan what are you posting on here for you sold your car to get a corally .. by the way i have been runnig a hot bodies car for a little over a month now and it has been by far one of the best cars i have ever driven ton of corner speed and easy to drive i love it
#8075
Originally Posted by rc-zombies
I was bored over the weekend... took out the dremel and....
#8076
Your Rear Diff. screw do you have broke ?
because many peoples also broke !
#8077
roll centres what do they do? ie i have never put shims under the pivot blocks before (thinking of trying 1mm all round) are you supposed to put them under the pivot blocks ie the front and back ones but do you put them under all 4 pivot (blocks using 8 shims) or just under the ones that you can change???????
#8078
Hello, this year we run with foams or rubbers, in asphalt. The majority of drivers run with foams, i run with Surikan Edition, with excelent results in regionals and Nacional, but now the days are very hot and i feel the car more soft, with foams .
My question are, ¿Is the BMI chassis for asphalt, more rigid that the std? and ¿it changes to much the behavior?, ¿where can i buy one? in the web of BMI i do not see it.
Greetings.
Greetings.
#8079
Gonna try a new spring from another company and see what happends.
#8080
#8081
I broke 7 diff screws in my first cyclone and zero in my 2nd. For minimal breakage use the Delrin outdrives the associated diff screws and nuts, and put a small washer in the outdirve before you put in the nut and you should have decent life out of them. There is a link somewhere where Hara shows the best way to build the diff. I also used all ceramics in my diffs and they were butter for 3 months till I sold my car.
#8083
for 479 bones no corally for me
#8085
Originally Posted by Jan Larsen
What drillhead did you use for that? Looks like it was done by a machine!
http://www2.towerhobbies.com/cgi-bin...?&I=LXHMT1&P=7
