Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 03-16-2007, 09:25 PM
  #7651
padailey's Avatar
13.5 with Sintered rotor people in our area are going up 5-8 teeth on the pinion from brushed motors. Right now I'm running a 46/90 and still not geared as high as some. If I were to start buying them now I would get 45, 46, and 47 pinions with 100 and 94 spurs. Shouldn't have any gear mesh issues with those.
Running rubber tire on carpet.
padailey is offline
Old 03-16-2007, 09:32 PM
  #7652
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
27 turn, i use a trinity co27 motor, and a lrp sr, known as the punch machine and it really is a TON faster then most, but only for 27 turn and 19.. all the racers here say mod and that is to much power, but with 27 turn it REALLY wakens up the motor
BlackedOutREVO is offline
Old 03-16-2007, 10:37 PM
  #7653
xray racer's Avatar
Trader Rating: 22 (100%+)
Just got hold of a Surikarn, does anyone have a weapon rubber tire asphalt and foam asphalt set-up they'd mind sharing???
Any help would be greatly appreciated,
Cheers,
Robbie
xray racer is offline
Old 03-17-2007, 03:12 AM
  #7654
kamikaze's Avatar
ok just run my wce cyclone for the third race meet, how the f... do you get the god dam diff to stay tight it loosens after every run and yes i have put the socalled heavy duty diff screw and nut and new spring in
please help im going nuts
kamikaze is offline
Old 03-17-2007, 03:15 AM
  #7655
Michael.H's Avatar
Get a 1/12
Michael.H is offline
Old 03-17-2007, 03:35 AM
  #7656
stephen hilton's Avatar
try using threadlock!
or......................... buy an mi3 and solve all your problems!!!!!!!
stephen hilton is offline
Old 03-17-2007, 07:24 AM
  #7657
Trader Rating: 208 (100%+)
Use a TC3 screw and nut. A little thread locker to.
dodgeguy is offline
Old 03-17-2007, 07:50 AM
  #7658
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
If using aluminum outdrives, check that the diff screw is not threading into the outdrive itself before getting to the diff nut. I had to drill both of mine out a little bit and that made a world of difference on my diffs.
Buying an Mi3 is not the answer, every car has its quirks you will have to work through. Although IMO its a visually pleasing car lol.
BillyCaldwell is offline
Old 03-17-2007, 11:11 PM
  #7659
Has anyone tried these new springs? They are not rated in a rate but soft, med and hard.
http://www.hbeurope.com/piw.php?partNo=66964&lang=en
dodgeguy is offline
Old 03-18-2007, 09:13 AM
  #7660
Stew Noble's Avatar
lb/in ratings for AH/HB springs.
SS-Yellow-12.8
S-Grey-13.9
M-Black-15.0
H-Purple-16.2
SH-Red-17.3
Stew Noble is offline
Old 03-18-2007, 09:47 AM
  #7661
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
BlueStreak362 here is the setup I used at Frederick.
wyd is offline
Old 03-18-2007, 05:12 PM
  #7662
cheehtae's Avatar
Trader Rating: 15 (100%+)
what's the biggest or most # of teeth you can install in a cyclone?
cheehtae is offline
Old 03-18-2007, 05:15 PM
  #7663
i want to know also, with the stock spur
how small, and big can u go?
Old 03-18-2007, 06:44 PM
  #7664
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
for the spur you can install a 110 (64 pitch)
Marcos.J is offline
  #7665
Super Moderator
Marcos.J's Avatar
i have used a 83t to a 110 t
Marcos.J is offline
