Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 03-11-2007, 10:02 AM
  #7576
dawgmeat's Avatar
Originally Posted by Vicko
well i not broken any hubs yets, I just want to get some normal ones
just in case I brake them, I know the old style dont fit very well, but the style dose not cause the streeing to bind
Depend how you drive I have not broken a diff screw yet
dawgmeat is offline
Old 03-11-2007, 10:06 AM
  #7577
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
well now you better get one just incase
Marcos.J is offline
Old 03-11-2007, 10:49 AM
  #7578
dawgmeat's Avatar
thanks for jinxin' me
dawgmeat is offline
Old 03-11-2007, 11:35 AM
  #7579
Super Moderator
Marcos.J's Avatar
Marcos.J is offline
Old 03-11-2007, 01:16 PM
  #7580
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
The past 2 weekend I've busted about 5 steerings blocks...... it's just driving me nutz because I went about 3 months without breaking anything, I remeber someone saying the T2 castor blocks & steering arms fit the cyclone well I gave it the ole' college try and they work but since I had to use Team Tamale I had to remove 2mm from the steering to keep the ackerman the same just out the pics
I use the composite t2 spindles and they work great. It helps they are sold individually so you dont have a bunch of spare rear hubs like the hb stuff.
BillyCaldwell is offline
Old 03-11-2007, 02:45 PM
  #7581
stuey's Avatar
Originally Posted by sidewaysdriver6
here's a list of the items you'd need to get :
1) P/N 73512 (hpi pro 4 stick pack holder), qty : 1 set
(this is a set of various parts, each marked with numbers. you'll only need the parts marked 4 (2pcs), 6(1pc), 7(2pcs) and 8(1pc) from this set. i'll refer to these as 73512-4, 73512-6, 73512-7 and 73512-8 respectively)
2) P/N Z082 (flat head screw m3 x 8mm), qty : 2
3) P/N Z352 (button head screw m3 x 8mm), qty : 4
4) P/N Z224 (washer m3 x 6mm), qty : 4
5) P/N Z305 (screw post m3 x 8mm), qty : 2
pics :
underside view
top view
top with battery clip view
steps :
1) cut out P/N 73512-7 (2pcs) from the set. dremel/file away the little "tooth" at the bottom of this part, so that it can sit flat.
2) attach the 2 pcs of P/N 73512-7 to the chassis, using P/N Z082 screws and using the existing unused holes along the centre line of the chassis, as in positions as shown in the "top view" pic.
Impt note : note the direction of the P/N 73512-7. this is the opposite way of how it's mounted on pro 4. this is to prevent the stick pack of getting in the way of the pinion and spur gear on the cyclone.
3) cut out P/N 73512-8 from the set.
4) put your stick pack on the chassis, and push the left side of the stick pack flush against the 2 pcs of P/N 73512-7 installed in step 2.
now place P/N 73512-8 flush against the right side of the stick pack, in the position as shown in the "top view" pic. mark out on the chassis the location of the 2 holes for mounting P/N 73512-8. the 2 holes must be located at a safe distance away from the side-by-side battery slots of the chassis.
5) remove the stick pack, remove P/N 73512-8, and drill the 2 holes marked out in step 4, using a 3mm diameter drill bit. make sure the bit is the type for drilling metal and is sharp (use a new drill bit if you can).
you'll need to clamp down/secure the chassis properly when drilling, to prevent any warpage of the chassis. i also use a vacuum and point it towards the drilling to suck away the cf dust.
along each hole (which will be very close to the side edge of the chassis), parallel to the battery slots, i use a needle file to file a slot from the side edge of the chassis, inwards towards the hole. this creates a "u-shaped" notch along the side edge of the chassis. this is to ease the positioning and mounting of P/N 73512-8 later on.
if you use CA glue to seal the edges of the cf chassis you'll probably want to seal these 2 notches too.
i'm not sure if the description of the notches make it hard to visualize, but i hope you can make out the 2 notches in the "underside view" pic above.
6) place the left side of the stick pack flush against the 2 pcs of P/N 73512-7, and then adjust and mount P/N 73512-8 using the P/N Z352 screws and P/N Z224 washers, as in the "underside view".
7) Cut out P/N 73512-6 and the 2 pcs of P/N 73512-4 from the set. dremel/file away the little "tooth" at the bottom of P/N 73512-4. screw in P/N Z305 screw posts into the 2pcs of P/N 73512-4, and then mount the 2 pcs of P/N 73512-4 onto the chassis using the existing slots in the chassis, and using P/N Z352 screws and P/N Z224 washers. with a stick pack on the chassis, adjust the positions of P/N 73512-4 until they hold P/N 73512-6 well, and then tighten the 2 pcs of P/N 73512-4 into location.
at the end of this you should see what you see in the "top view with battery clip" pic.
that's it! the above instructions may seem like quite a lot of work but it's actually a pretty simple straight-forward change. main thing is to be careful with the drilling. the disadvantage is that there will be 4 button head screws on the bottom of the chassis. but i have my ride height set pretty high and run on pretty smooth concrete ground so this isn't an issue for me. if you have access to machining equipment that can make accurate countersunk holes into a cf chassis that would be a great way to solve that.
anyway hth and good luck ! if you have any questions just post back.
that looks all good but why didn't you use counter sink scews most indoor clubs in the uk would not let you race with those screws hanging out.
stuey is offline
Old 03-11-2007, 02:47 PM
  #7582
yeah, counter sink it and use flat heads and that will look real nice. I used some of the xray stuff on mine, made a g10 strap and used xxx4 battery posts.
Old 03-11-2007, 07:10 PM
  #7583
Greetings all,
What are the differences between the regular cyclone and the new Andy Moore edition?
Obsidian is offline
Old 03-11-2007, 07:43 PM
  #7584
Super Moderator
Marcos.J's Avatar
Originally Posted by Obsidian
Greetings all,
updated cvd's ,new spool,shock towers,some titanium parts ,diff screw,and alot of purple stuff
Marcos.J is offline
Old 03-11-2007, 09:11 PM
  #7585
thanks. i use this to drift so no race/legality issues for me.
i didn't use counter-sunk screws as i haven't figured out a good way to make neat counter-sunk "V-shaped" grooves on the bottom of the chassis . any recommendations?
was thinking about using a dremel but i'd think it's gonna be rather hard to get the right angle of the groove by hand?
sidewaysdriver6 is offline
Old 03-12-2007, 04:00 AM
  #7586
pookat's Avatar
Maybe try a countersunk drill bit
pookat is offline
Old 03-12-2007, 04:46 AM
  #7587
Like this.
$8 bucks at Amazon.
Irwin Countersink Bit
When I don't have a countersink bit I just use a regular large metal drill bit to create the countersink. The angle isn't perfect but it is better than no countersink.
Disaster is offline
Old 03-12-2007, 05:06 AM
  #7588
cheehtae's Avatar
Trader Rating: 15 (100%+)
anybody tried the jet racing c's and knuckles?
cheehtae is offline
Old 03-12-2007, 05:16 AM
  #7589
dawgmeat's Avatar
don't waste your $$$ go with 3 racing
dawgmeat is offline
Old 03-12-2007, 05:20 AM
  #7590
Super Moderator
Marcos.J's Avatar
i prefer the stock ones my self
Marcos.J is offline
