Hot Bodies Cyclone
#6736
Originally Posted by HEWITT
hey guys, has anyone ran the cyclone with foams with just the stock chassis??
#6737
Suspended
the stock chassis works very well iv been running it for alomost a year now even tho i have a bmi the stock chassis still feel more planted when teh grip is lower or the track is very very tight.
Hey Larry how are you liking rubber? what tires are you using?
how do the laptimes differ from foam?
we are tryimg to make the switch to rubber at my local track just tryin to find a good spec tire
#6739
I am running cs27s. Tried 30s too and they seemed similar but Im still a carpet rubber rookie so I dont really know.
Its definatley fun and easier, there is no tire wear really there are probably 20 or more runs on my current tires and they still look great.
#6740
Originally Posted by L.Fairtrace
Rubber is cool, Im still getting used to the oneway, first time I have run one. My car is coming around, Im about 1.5 seconds slower than our best 19 turn foam laps.
2008... ROAR Moves to CARPET RUBBER TIRES!!!
#6741
HB cyclone Moorespeed diff problems
Ive been racing my HB moorespeed for about a month now using stock motors (27t). I already had two titanium coated diff screws break on me and problems with the Mip driveshafts pins popping out.
Has anyone else been experiancing these problems, i know alot of people have had problems with the diff screws, has anyone come up with a solution or is there a different make diff i can use or diff screw?
The second diff screw i'm still puzzled how its broke, the car was fine at practice and going really well, taken the wheels of 2nite and noticed that the diff is now broke!
Any advice would be most appreciated
Mike
Mike
#6742
i havent had that problem but i have had a problem with play in the wheel bearings all 4 are very loose and have lots of play can any one help.only used the car two times.not happy and mirage dont want to help??
#6743
#6745
Hope this helps
#6746
Maybe once you tighten your wheel lock nut on the wheel, hex begins to push torwards hub and sit in properly.
#6747
I don't say it to hard, but I never broke an diff screw so far and ran several times with 7x1 and 8x1 Mod. motors indoor.
Rob
Rob
#6748
Mike
Mike
#6749
Originally Posted by BigDaddyT
Hey Stephen - I run rubber stock all the time at our club. The one-way is definitely the way to go for Stock. Once you get used to it, it will allow you to maintain your momentum and corner speed a lot better out there.
The car will initially feel like it has way more (too much) steering. You can dial this back a bit on the radio and then soften up the rear end of the car a bit. When it's working, it will have really aggressive steering, but not oversteer. It will take some tweaking to get it right for your carpet. I find that I usually start with the rear shocks laid down pretty far and then stand them up a hole as traction comes up on the track.
#6750
cheers
