Hot Bodies Cyclone
#3361
Comes with a front one-way and spool.
Comes with a centre one-way and locked pulley - very handy.
Shame it only comes with one front plastic pulley that you have to swap between the one-way and the spool
#3362
Suspended
very nice car....i have the regular cyclone version....i am now about to start on it.....
#3363
It would be interesting if they release blue toe blocks as well other than 2.5 & 3 degress. Looks good
#3364
Originally Posted by Ballsie
I'm still building my Surikarn kit and the shocks are easily the worst I've ever built
Trying to get the ball joint to the end of the shock shaft is nearing on the impossible. Out of the 4 I have 2 that are barely on, 1 a little more so, and one nearly fully on.
I just can't get the shaft to stop rotating when I try to tighten the ball joint - anyone got any ideas?
#3365
Originally Posted by robk
Get a 3mm tap or use a cap head screw to start the shock end first. Should make things eaiser w/ the shock shaft.
I hope they bring out the full set of toe blocks in blue too.
#3366
Originally Posted by rcpoint
Got it, back straight is 125m (410ft). I'm still looking for that FDR. btw you're all welcome to try it, it's the best track in Holland (and my club). Jilles Groskamp started here.
#3367
hey guys,
i am almost finished with my prototype bulletproof spool for the cyclone.i just need to crosspin the outdrives and put in the pulley mounting holes.i am gonna try it out this weekend and try to beat it up and make it surrender.i will let you know how it holds up.if it doesnt i will make it stronger.let me know what you think so far
#3374
Jason,
Would this spool setup work with 27 turn stock & Sorex 36/C-med inserts? Pm it to me as well then.
#3375
Spool+center One-way or Spool+fixed pulley
For medium to High grip asphalt, which is more better Spool+center One-way or Spool+center locked pulley?
