Hot Bodies Cyclone
#3392
Thanks I was looking everywhere
#3393
Hara Features:
• 39 Tooth Pulley (Ball Differential)
have they decided to sell a ball diff for the new cyclones or is that the rear diff as in the original...?
#3394
Originally Posted by cyclone
Hara Features:
complete ball diff kit... haven't seen that released yet.
#3395
Suspended
i am about to start my regular cyclone kit...what to look out for,what do i need to get and what do u think is a good motor,esc,batt pack,tires..etc...thanks...red
#3397
HPI Racing Spring Rates:
Blue - 273 gF/mm
15.3 lb/in
Silver - 302 gF/mm
16.9 lb/in
Pink - 320 gF/mm
18.0 lb/in
Gold - 340 gF/mm
19.0 lb/in
White - 363 gF/mm
20.3 lb/in
Yellow - 388 gF/mm
21.7 lb/in
Red - 400 gF/mm
22.4 lb/in
Blue - 273 gF/mm
15.3 lb/in
Silver - 302 gF/mm
16.9 lb/in
Pink - 320 gF/mm
18.0 lb/in
Gold - 340 gF/mm
19.0 lb/in
White - 363 gF/mm
20.3 lb/in
Yellow - 388 gF/mm
21.7 lb/in
Red - 400 gF/mm
22.4 lb/in
#3398
Originally Posted by Nexus
I see you are developing a thicker carpet/foam chassis but what is the advantage or your asphault chassis?
Just wondering since I thought the stock chassis was designed with asphault/rubber tire racing in mind.
Either way I'm sure yours will be top quality I'm just asking since I'm considering purchasing the Cyclone SE.
basicly what i am going to do for the asphalt chassis is change the flex characteristics a little bit and also use better c/f that will not hold twist.i am going to keep the same amount of flex because the car does work extremely well and i am very pleased with the layout of the car.i would also like to see the flex point of the car be a little more centralized than at the rear.its not going to be drastic changes because i am really pleased with the car.i am just looking to see if i can improve.if not i will not release it.
#3399
Suspended
Originally Posted by RaceAce701
what class are u planing on running in and on what surface.
#3400
Trader Rating: 51 (100%+)
Cant wait to get one for my Cyclone :-)
#3401
Hi Jason
Do you have an idea when and if you are going to make a chassis for foam on high bite carpet
Thx
Lou
Thx
Lou
#3403
Trader Rating: 22 (100%+)
Originally Posted by danjoy25
Jason,
Would this spool setup work with 27 turn stock & Sorex 36/C-med inserts? Pm it to me as well then.
#3404
i dont remember if i answered the question in that quote but yes it will.i ran that setup on my stock car and it was the fastest i have gone with the cyclone so far.right now my spool car is the faster of the 2 cars.i am getting better with the oneway and am very happy with it.i am just always been a spool guy.i am running haras setup on my oneway car and really like it alot.i have been running my oneway car in stock and my spool car in mod because i need the brakes.i am always faster with a spool though.hopefully i will be able to be faster with a oneway because tires get expensive after a while and the oneway seems to be easier on tires.
#3405
Super Moderator
