Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 03-18-2006, 08:11 AM
  #3226
Hollowman's Avatar
I don't have any problem with my diff, but as many people here the head of my diff screw popped off but that happend once and now my diff is fine
Dutch : hey, rcpoint al met je cyclone gereden ?, goeie site he zoveel info
Hollowman is offline
Old 03-18-2006, 07:25 PM
  #3227
floodo1's Avatar
sanded graphite looks nice to me!
i did that on my oval car once
floodo1 is offline
Old 03-18-2006, 10:51 PM
  #3228
Nickmind's Avatar
Were is the best place to buy a Cyclone?
Thanks,
Nick
Nickmind is offline
Old 03-19-2006, 12:04 AM
  #3229
XrayFK's Avatar
Originally Posted by cyclone
on page 102, hara is doing his build tips... at the top hes dremeling some alloy away for the belt and the steering linkages, is this a problem on the original edition cyclones? if so will it be changed on the new ones?
cheers
andy
It's not really a machining error or anything, it's just that the block will hit the steering linkages if you raise it high enough with shims.
XrayFK is offline
Old 03-19-2006, 12:05 AM
  #3230
XrayFK's Avatar
Originally Posted by rcpoint
More specifics about a diff:
After 4 runs diff gets very loose. I've tried almost everything to keep it tight, but no luck.
What motor are you running? Also, check back to page 102 I think and look at Hara's building tips on the diffs. I've had no problems with my diffs.
XrayFK is offline
Old 03-19-2006, 12:12 AM
  #3231
XrayFK's Avatar
Just noticed, that the next segment of Hara's tips are up: http://www13.ocn.ne.jp/~mirage-j/AH/...yclone02.htm#2
XrayFK is offline
Old 03-19-2006, 12:35 AM
  #3232
SpeedDesignz's Avatar
Has anyone tried the reversed rear shock mod on thier Cyclone yet ?
I did it to my Pro 4 this weekend and the car rotates sooo much better.
carpet
foams
that is
just want to get some opion on set ups
the belt car may not be far off
SpeedDesignz is offline
Old 03-19-2006, 12:42 AM
  #3233
lookinco's Avatar
I broke my diff screw again today! When can I get the Titanium ones !
lookinco is offline
Old 03-19-2006, 12:47 AM
  #3234
XrayFK's Avatar
carpet
foams
that is
Do you mean to mount the shocks in front of the arms? Do you just reverse the directions of bulklheads and what not?
XrayFK is offline
Old 03-19-2006, 12:59 AM
  #3235
Dutch: Ik heb er mee gereden op heemstede, een top auto.
Used 12x1 motor (orion)
rcpoint is offline
Old 03-19-2006, 02:02 AM
  #3236
JoeyE's Avatar
Trader Rating: 45 (100%+)
I have a Cyclone for sale if anyone is interested. (My spare)
http://www.rctech.net/forum/showthread.php?t=106414
JoeyE is offline
Old 03-19-2006, 03:04 AM
  #3237
lookinco's Avatar
You have PM =)
lookinco is offline
Old 03-19-2006, 04:27 AM
  #3238
carpet
foams
that is
Do you have a pic of your PRo 4 with the modification on the shock tower?
benoitrdv is offline
Old 03-19-2006, 04:54 AM
  #3239
noline's Avatar
I have a delema with my Hot Bodies Cyclone I bought it 2nd hand but its in mint condition only one or two runs on it the problem Im having is when I make a right tight turn it wants to spin out but when it turns left its fine I put it on a MIP Tweak station to see if it was out of tweek and when I looked at the bubble it was dead center I did that for the front as well and it was dead center as well so I looked over the whole car to see if anything was bent or binding up and everthing was fine I ran a brand new set of Take offs CS-27 and it still spins out I ran the same tires on a differnt touring car to see if it was the tires but they where fine to I checked all the shock lenghts and they where fine as well and I checked the sway bars to see if they where bent or binding up and they where fine to I also looked to see if any screws where loose but that was Ok to the setup Im running is the asphalt setup on the back page on only changes i made to the car was I built a front diff and a center locked pully my only guess now I maybe the chassis could be tweeked if any one can please help me I would greatly appreciate it its driving me crazy!!!
noline is offline
Old 03-19-2006, 07:06 AM
  #3240
JoeyE's Avatar
That happend to me before when I first drove the Cyclone. I found out "my" problem. It was the tires. I had a brand new set of Rides 36's. Couldn't figure out what was going on. Everything checks out fine. My friend told me to change the tires and then it was hooked up! I ended up using my used set of Sorex 36's. Some times it could be as simple as that. The center line on the new tire sets throws the car off a little.
You can also check your droop and ride height. What oil in your shocks? Are they all evenly filled? Springs being to soft? Racing mod or stock?
JoeyE is offline
