Hot Bodies Cyclone
#2071
Has anyone tried the new strengthened upper bulkheads from jet racing
#2072
Originally Posted by pucho
I think I figured out the difference between the two HD driveshaft Part #s, I bought some Rears because the fronts weren’t available. Well I have been using a diff and there was no problem, yesterday I go to put in the one way and SOB the ball end won't fit into the one-way cup. I tried the aluminum ones and they effectively have a smaller end on them. I'm waiting on some fronts to confirm.
the fronts are also a lot thicker, and heavier, than the rears.
attached is a pic of the three dogbones, top - hd front, middle - hd rear, bottom - alu (bent and twisted)
#2073
Originally Posted by EvilDriver
I already did that.. and I used the Allen Wrench that came from the Kit but the set screw keep on loosen out.. so now like My previous Post used the Blue locetite, to make sure it will not loosen out.. if this doesn't work I'll just have to use the green locetite. .
Tom :
4: the kit come with 3 sets of sway bars.. copper 1.2 mm silver 1.4mm and black 1.6mm, the fronts and the rear ones are diffrents.. the rear one is slightly longer.
6: 64 pitch and 100t Xenon spur, the biggest one I've seen been used is 108 64 pitch spur.. it said on Hara's Set up sheets. and a couple page behind someone said that for 48 pitch 80 spur is the biggest you can put on.
8: same as pro4
Hope this help..
I'm just emphasizing what the other guys have told you..and adding some details.
Tom :
8: same as pro4
Hope this help..
Will you race for national on 11 December ?
#2074
Originally Posted by asw7576
Why not using longer screw ? I have longer one in my box if you want.
and yes I'll be racing in the Nats on dec 11.. .
#2075
Originally Posted by JoeyE
Just got word today from RCS, Thailand(where Surikarn practice). There is going to be two versions. One will come in all purple. Something like a HARA Limited Edition and the other in blue trim. You know, SURIKARN color. I think my next one will be blue!
Due out sometime in January.
greetz hollowman
#2076
#2078
Hollowman where do u race in holland?
in PKracing?
in PKracing?
#2079
No, i run at MBC De Sluis ''Gouda'' I am MaXX Cellrated Rc Freak on modelbouwforum.
Greetz Florian
Greetz Florian
#2080
i have a qestion
when do i have to use a 1degrees pivot block
en when a 2.5 degrees? on the front?
#2082
http://www.radiocontrol.gr/news_hot_...ons_091205.htm
"There will be 2 new types of cyclone to be released soon: The Hara & Surikarn Edtions!
Of course this chassis includes more spec then the orginal cyclone:
1. All aluminum parts will be blue or purple from black
2. Front Solid Axle included
3. Aluminum Out Drive (for Ball Differential) included
4.Aluminum Servo Mount included
5. Updated Upper Bulkhead included
6. Updated Middle Block R included
7. Center Shaft for no one-way included
8. 16T Center Pulley included (Total two 16T Center Pulley)
9. New 39T Pulley (Narrow Type) included
10.Front Shock Tower 3.5mm
11.Rear Shock Tower 3.5mm
12.Updated Main Frame 2.5mm
13.Aluminum Spring Mount included (#31413) Bule"
#2083
From the Xray T2 thread:
I've been running my FK05 for 9 months....the Cyclone is 3 months old and there are new versions coming....If Xray is pathetic for launching a new car 9-10 (basically 10 moths after launch give or take a few weeks) what does that make HB with new versions within 4 months(If the January release date is true)???
The new versions sound like they have some worthwhile additions...but only 4 months after the launch of a premium priced kit has to hurt...
Originally Posted by ngo8
this is so pathetic X-RAY is becoming worst the Tamiya
#2084
its not out yet it wont be out for like 1 year or so
#2085
hmm i just bought the cyclone. if they really come out with new versions in january then i'm sure i am not the only one who will be really pissed. there goes the resale value of my car.
screw the jap manufacturers. should have stuck with the american/european brands.....
