Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 09-29-2009, 04:32 PM
  #17506
TheCoolCanFanMan's Avatar
Originally Posted by ShaunMac
Exactly. That's a 1.5mm Over Ride Height droop setting.
Sweet cheers
Malc
TheCoolCanFanMan is offline
Old 09-29-2009, 04:33 PM
  #17507
Trader Rating: 114 (100%+)
Is the Cyclone a Lipo Friendly car? I thinking about getting one for 17.5 sedan/RCGT. Is it hard to take a Cyclone and make it a "S"?
Dave
dragracer72nova is offline
Old 09-29-2009, 05:23 PM
  #17508
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by STLNLST
Slaving is more like it....
The HB was working pretty well this weekend. I'll have my set up posted on gearchart later on today when I get some time. Korey gave me the set up and I tweaked it to fit.
Thanks Korey for all your help.
Hiro- Race report will come shortly. I'm still tired but I have to go to work now
Or slacking talking to me
How was the regionals?
BlackedOutREVO is offline
Old 09-29-2009, 07:44 PM
  #17509
rcfiend's Avatar
Trader Rating: 42 (100%+)
Hey guys I just picked up a a used TC and I have a few questions. I noticed that the guy I bought the car from has the purple rear uprights and he has the graphite ones on the car. Which is better to run and which ones do you guys have on your car? Thx guys.
Keith,
rcfiend is offline
Old 09-29-2009, 08:53 PM
  #17510
ShaunMac's Avatar
Keith,
I have always run the standard kit hubs. The aluminium parts do hold up better, but only by shifting the force of an impact on to other parts (hinge pins, A-arms). The standard parts hold up nicely and most racers use them throughout the entire car.
If the aluminium hubs are 1 degree (as opposed to the stock 0 degree) you could use them as a tuning tool if traction drops really low.
Enjoy your new ride.
ShaunMac is offline
Old 09-29-2009, 11:15 PM
  #17511
Keith,
I run the alloy uprights on my TC, as there was a bad batch of rear up rights, that were showing i think around about .5 degree toe difference from side to side
subdriftr is offline
Old 09-29-2009, 11:43 PM
  #17512
decibels's Avatar
hey just a quick question on the version 3 spool. Are the optional pom outdrives plastic or steel? they look plastic as there looks like a cover to slide over the outdrive but just wanted to clarify.
decibels is offline
Old 09-30-2009, 12:24 AM
  #17513
They are plastic. POM = Plastic
billythekid is offline
Old 09-30-2009, 12:29 AM
  #17514
I think all the hubs that came with the kit are bad. I am not sure how to identify which are good and which are bad, perhaps Hiro can help. The hubs that came with my kit showed close to 1 degree difference between left and right.
Old 09-30-2009, 04:08 AM
  #17515
Default springs
Hi can some one tel me the spring rates of HPI [hot bodies] I resintly got a new tc and i got gold and silver springs with the kit.. and how it compaer with XRAY spring sets
diffscrew is offline
Old 09-30-2009, 06:58 AM
  #17516
Korey Harbke's Avatar
They are a type of delrin. It's the same material that is used in the standard kit rear diff outdrives in the TC kit. They work great!
Korey Harbke is offline
Old 09-30-2009, 08:59 AM
  #17517
Scott B's Avatar
Trader Rating: 47 (100%+)
Red 22.4lbs
Yellow 21.7lbs
White 20.3
Gold 19lbs
Pink 18lbs
Silver 16.9lbs
Blue 15.3lbs
Scott B is offline
Old 09-30-2009, 09:27 AM
  #17518
rc pete's Avatar
Originally Posted by Hi-LowBlow
Where have you been Peter??
We don't do much asphalt racing around here, so I've been keeping busy running the D8 during the summer. Braaaapp!! Man, that's fun!
I've put that on the shelf and I'm dusting off the TC.
Our indoor carpet season starts up this week.
rc pete is offline
Old 09-30-2009, 08:21 PM
  #17519
Trader Rating: 40 (100%+)
I've read through about 50 previous pages with no luck, but what lipo packs wil fit without the lipo conversion or any type of modifying? I should have my cyclone tc the beginning of next week so I'd like to go ahead and get me a lipo ordered as well! Beginner question here, the only tc i've owned was a t2 and I've only had it for about a month. When I got it, it came with the lipo,esc/motor and servo. It was already balanced left to right. Are the small weights that the previous owner used to balance it the best thing out there to use or is there something better? I'd like to do the cyclone right so if there's something out there that I can use to balance it better I'd like to know about it.
AndysD8 is offline
Old 10-01-2009, 01:29 AM
  #17520
masher's Avatar
@AndysD8 I use a SMC 4000 35c pack wich is thinner than my SMC5000 packs, and that fits with no mods at all. The taller packs you just have to dremmel 1mm of the bottom off the mount..hope that helps.
masher is offline
