Hot Bodies Cyclone
EU SUBARU IMPREZA TYPE B
Designed and developed by Team Hot Bodies touring car racers, this is the latest HB bodyshell designed specifically for pro-level racers!
The Subaru Impreza Type B replicates the endurance and touring car racing STI variant that competes in pro and semi-pro on-road racing around the world. The sleek lines of the HB Type B bodyshell provide immense downforce, straight-line stability and cornering levels that approach pin-point accuracy.
Ultimate Racing Performance
This body was designed, tested and proven on the race track. HB designers and team drivers did extensive testing using several different body shapes and aerodynamic variations. The result of the testing is the 'Type B', which outperformend other versions in steering response and stability.
High Performance Aerodynamic Features
The Type B body looks great, but it's not just about looks! The scoop on the hood and the spoiler on the rear window gave the body more stability during track testing. The smooth front bumper features a large splitter for high downforce and maximum efficiency. Flat side panels provide consistent stability on the track, and the door areas are reinforced to reduce deflection at high speeds. Extra-large wing mount areas transfer all the downforce from the wing to the rear suspension for increased traction.
Direct Fit for the Cyclone TC
Body post marks make it easy to fit the Type B to the Cyclone TC touring car, and calibrated wheel centre marks allow you to easily match the wheel openings to the wheelbase of your chassis. Extended mounting lines allow you to accurately move the body forward or backward on the chassis to fine-tune the handling of your car.
Officially Licensed
This bodyshell isn't just based on the world-famouse Subaru Impreza, it's an officially licensed product!
Top racers will notice the measurable difference in car feedback when using this bodyshell, and every touring car driver will love the dramatic increase in traction over older designs. With highly improved aero balance, you're practically guaranteed lower lap times on the track!
Racers of all skill levels on any type of track surface will really appreciate the attention to detail and performance, as well as the availability of a new, cool bodyshell to use!
Max Performance Hint: boost performance by reducing the gap between the front foam bumper and the inside of the bodyshell.
Officially Licensed
who knows any store do make a pre-order? hehehe
Neither these 2 bodies which announced in twice months ago are selling in somewhere:
09X
Type B-C
...and much more!
Maybe they have trouble in the factory or just selling some kinds in determined countries?
In case these kinds are appearing just in the EU site.
Somebody tell us when could we buy HB bodies, please?
Hey guys, I bought my son (Alex) a Cyclone S kit and we have been slowly upgrading and fine tuning. We finally are getting some pretty good lap times and he is competitive on track. Now he wants to switch to the carbon fiber chassis for the Cyclone S (p/n HB70728), has anybody been down this road ? is it a good change or should we stick to the plastic chassis ?
Thanks, Phil A.
Thanks, Phil A.
Hi Guys
Any idea where I can get the low friction white belts for the Cyclone TC as Team Bomber used to sell them, but for the WCE version only, as the TC have 18 teeth pullys they need to be longer, any help would be appreciated.
Cheers Malc TCCFM
Cheers Malc TCCFM
Ok, if you are really interested about this body!
09X
Type B-C
...and much more!
09X
Type B-C
...and much more!
-Korey
Hi Guys
Cheers Malc TCCFM
Cheers Malc TCCFM
-Korey
Thanks, Phil A.
Thanks, Phil A.
I'm glad your son Alex has bee doing well with the car! I knew he is a great driver so not big surprise.
As for the main chassis upgrade from the tub chassis to the graphite chassis, I think it would be a good change to try. Actually the tub chassis works extremely well especially on low bite, but it's a bit heavier and keeps the motor a little bit hotter due to the less air flow.
I believe that the part number #HB70728 is the part number for older main chassis and it's already discontinued. The new part number for the new refined chassis is #67702.
Please let me know if you have any questions.
I hope i will see you at race tracks in socal (Yes, now we have choices!)
-Hiro
09X
Type B-C
...and much more!
09X
Type B-C
...and much more!
Hi EJ20, as Korey mentioned earlier, this body will be available very soon at your local hobby shops. (or you can order directly from our web page) Sorry it took kind of long to be available, but now it's finally released.
Thank you.
-Hiro
Thank you Hiro, I've been patient on waiting for that too.
im selling a Surikarn WCE Cyclone
PM me for details/pics
Hi Phil, It's Hiro.
-Hiro
-Hiro
Thanks for all the info and look forward to seeing you soon. Look for a PM from me.
Phil A.
Location: Returning to the hobby after a lengthy hiatus.
I just snagged a Cyclone off eBay. This thread has been like an encyclopedia of information.
Hot Bodies would be up the the Cyclone 4 by the time I got through this whole thread.
