cool can fans
#47
tryhard,
yep, he's already getting brackets made up with 2 fans fitted. i had a look at the 415 prototype he's made up and it looks good i will email you a list of the stuff he is doing, you can then show it to your friends and people you race with ( hint hint )
thanks for the help
J-P
thanks for the help
J-P
#48
No prob, I will do
(I get the hint )
(I get the hint )
Originally posted by J-P
tryhard,
thanks for the help
J-P
tryhard,
thanks for the help
J-P
#49
is this fan to be used while racing? if so would it not make sense to have the fan sucking instead of blowing air back in the can? otherwise you are just blowing hot air back onto the can.
#50
hey pheyhoe,
we've talked alot about this and tested the fan blowing or sucking and found the best results and temp drop to be from the fan blowing onto the com area. and now with the twin fan nearly avalible you can cool the com and the can at the same time!
hopefully going to get a web page set up showing the all the fans avalible in the next couple of weeks, and some new products that are on their way from my friend at RC Inovations!!!
J-P
J-P
#51
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
MR RC Inovations has got a spray glue activator, this is real good for getting those glued wheels to cure in a instance, also the super glue he produces stay`s flexible after it has cured & flexe`s with the trye which is nice
Where`s my fan
Where`s my fan
#52
just wanna show you guys how i mounted my associated fan on my FK.
#53
hey pheyhoe,
J-P
hey pheyhoe,
J-P
#54
TRF415boy,
thats exactly right, maybe i should have just said that
S-T-R-I-K-E-R,
very nice work, does it add much weight?? if so how much??
MR JOLLY,
im sure malc wont forget the help you've given him, im sure it's in the post but the carbon ones will be in real soon hopefuuly by the weekend and then i will be getting mine then they will be going out to the people who have preordered them.
J-P
S-T-R-I-K-E-R,
MR JOLLY,
J-P
#57
hey dodgeguy,
we have a fan and bracket that will fit on and is designed for the XXXS, PM me with your email and i can send you a pic of it mounted on the car.
J-P
J-P
#59
Berger,
the ones we are using on our's are 25mm/25mm/10mm. the voltage is 5v and the cfm is 3.5.
J-P
J-P
#60
Has anyone found a place to buy the 25x25x10mm fans online at a reasonable price?
