Xray T1FK05
#5206
The axle in not moving in the suspension holders. So the angle of the axle in the suspension holders is NOT a problem when applying toe in.
The issue is:
1) The suspension arm is not freely moving over the 3 mm axle. Solution is to drill carefully the 2 holes in the arm and make it by that move flawless.
2' The suspension arm is squeezed by the suspension holders when fitting the screws. Just take a little material away from the arm to free that.
The issue is:
#5208
The adjustable upper deck it basically the only thing I got for the car, and it is well worth the money. It gives you a lot more tuning options then the stock upper deck...
#5209
Joep,
Thanks very much for the advice.
MIKE
MIKE
The issue is:
The issue is:
#5210
the most important upgrade on the fk05 is steel axels on the front the standard one always end up buring then you cant get them out of the knuckle
part number 305315
also the motor guard part number 303060
and the battery strap part number 306162
the fk05 battery holder has been superseeded by the T2's one part number 306163
part number 305315
#5211
Thanks for the help.
I will probably get the adjustable upper deck to better suit the changing traction levels of a parking lot track.
I already have one dimple in my body from the body being pshed againt the endbell of the motor, so the motor guard is an essential.
I won't be getting the battery strap, even though it is an awsome design as I hate small clips, I already use strapping tape and love it, it is so easy to change battery's and without any pots or other things in the way it is easier to change pinions and work on parts of the car.
#5212
i actually made a motor guard from an old evo2 chassis there are 2 parts of that chassis that can make them one is at the front and the other to make a more funky guard is around where the motor goes on the old evo2 or fk04 chassis
as for the battery srtap well i was using the tape for a month or so and ive been so much happier with turning one thumb screw to get my packs in and out
i had a mate using tape he ran over a corner dot and it ripped the tape and one of his best packs fell out and got damaged on the road
but dude trust me the steel axels if xray didnt make them I wouldnt drive the car
#5213
part number 305315
part number 305315
#5214
Just bought a used FK05. I'm a newcomer to RC racing and I will race indoor carpet on a road course. Team Associated seems most popular where I come from, but I'd like to be a little different. Heard many good things about the FK05's quality, ease of maintenance and ability to win races. How is parts support? Do you expect parts to be available for a few more years? Who is good for mail order supply of the parts (and ships to Canada?). Do I read you right that the T2 battery strap substitutes perfectly for the discontinued T1FK05 battery strap?
#5215
Very good choice. Have fun and lot's of nice races with it!
All parts are available and will for some time.
I leave that to someone else to answer (I live in Holland )
Yes, it fits and works fine.
#5216
http://www.speedtechrc.com/
I've had good luck with them. You'll love the TK05, it helped my driving. the car gave me more confidence in where it goes when I point it!
#5217
Just got a FK05, and I see why you guys recommend the steel axles for the front Any suggestions on how to pass the stock axels through the bearing on the steering arm, my stock axels seam to have slightly warped due to rubbing on the dog bone.
#5219
Thanks for the info. I was afraid that was my only option. Is this caused by oversteering?
#5220
kylehirano.
I used a small file to remove the flared out part of the axle, that way you can reuse it and not destroy the wheel bearings.
Usually a good hit will turn the str to far and bind with the dogbone, when you change to the steel axles then it will just bend the dogbone.
Fred
Fred
