Exoteck XR3'12
Old 05-16-2012, 01:19 PM
  #31
Fred Hubbard's Avatar
Originally Posted by Magnet Top
The xr3 kit comes with B , C , D , and B/XB ( according to the website )
B and C in the front, and XB/B and D in the rear.
To get to the Xray kit front width ( 1.5mm with no sweep ) what is used ?
Two C's ? Two D's or Two E's ? or Two F's ?
are the steps between letters .5mm ? or ???
The steps are .75mm (measured from the center of each pin hole)
D's in FF & FR are equivalent to kit.
Fred Hubbard is offline
Old 05-16-2012, 01:46 PM
  #32
Magnet Top's Avatar
Originally Posted by MikeXray
I've seen various cars running it, seems no one wants the nub, even some home made narrow chassis It's not impossible to break loose, but it takes alot. People who just CA the edges of the servo too the chassis seem to have them break loose more often.
Thanks !!!
Magnet Top is offline
Old 05-16-2012, 01:49 PM
  #33
Magnet Top's Avatar
Fred, thanks for the clarification .
Do you know if Nor-Cal is going to stock the optional exotek toe blocks, or should I call them to bug them about doing so ?
Old 05-16-2012, 03:27 PM
  #34
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Hey Fred
this is what I have on my xray...front are E,1/0 spit and the rear are E,Xb..
OVA is offline
Old 05-16-2012, 03:47 PM
  #35
Originally Posted by OVA
Hey Fred
That rear toe config should put you around 3.5* and the front would be like running 2.25mm (1.5mm + .75mm) in the FF with arm sweep, so overall your car is pretty wide.
Old 05-16-2012, 03:51 PM
  #36
Not sure Jake, I'm sure they would appreciate a "heads-up" from you about stocking them
Old 05-16-2012, 04:08 PM
  #37
theatriks's Avatar
any of u guys running the exotek try the VBC chassis as well ....just curious on a comparison?
theatriks is offline
Old 05-16-2012, 07:13 PM
  #38
OVA
OVA's Avatar
got it..Thanks
OVA is offline
Old 05-17-2012, 10:56 AM
  #39
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi All,
Here are the block widths for pin spacing;
BLOCK HINGE PIN SPACING FROM CENTER TO CENTER;
XB= 40.75
A= 43MM
B= 43.75MM
C= 44.5MM
D= 45.25MM
E= 46MM
New XC/c and XA/a split blocks just went into production to give you even more options
MikeR is offline
Old 05-17-2012, 11:05 AM
  #40
OVA
OVA's Avatar
Originally Posted by MikeR
Hi All,
XB= 40.75
A= 43MM
B= 43.75MM
C= 44.5MM
D= 45.25MM
E= 46MM
Good to know ..Thanks
OVA is offline
Old 05-21-2012, 11:18 PM
  #41
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Recently put mine together, all went well, looks impressive, hopefully see how it goes Friday night..
FK05 lover is offline
Old 05-30-2012, 05:30 PM
  #42
MikeR's Avatar
Congrats Aaron Young- Made the A-Main at Reedy in both 17.5 and 13.5 running the XR3'12! Arron reported he had some electrical problems all weekend but even so still made the big show in both classes.
MikeR is offline
Old 05-30-2012, 05:36 PM
  #43
Default reedy
There was actually two exotek xrays in the 17.5 a main .Car was really good all weekend and consistent but good luck wasnt on my side.
AARON YOUNG is offline
Old 05-30-2012, 06:00 PM
  #44
Magnet Top's Avatar
Thumbs up
I was the other Exotek XR3 '12 T3 conversion that made the 17.5 A main at the Reedy race. Aaron helped me with setup all week which was instrumental in me making the "show". Thanks again .
Jake D.
Old 05-30-2012, 06:14 PM
  #45
Default Reedy
Thanks for the props Jay , two cars in the a says something for the chassis
