View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#5524
Depending what chassis you run, a heavier pack may make it easier to meet minimum weight, or help balance the car a bit.
#5525
No cracks yet!!!
Very happy with this body!!
#5526
Anything legal that fits, at a price you feel comfortable with, from a reliable vendor. Battery specs aren't really all that crucial. Pick a pack (almost any pack) and go have fun.
I think I have run every VTA body available except for the Parma bodies and Protoforms new Firebird. The McAllister Firebird has been the best body yet. Its one piece construction makes it very durable and after a hard crash if the front edge of the fender buckles in it just pops right back out.
No cracks yet!!!
No cracks yet!!!
#5528
Tech Legend
We run just VTA here so I used the packs I already have from 4x4 sct, some 7200mah batts. When comparing them to what guys who were configured for pure USVTA They ran a whole bunch more chassis balancing weights than what I did. I think I only need to add about 70 grams or so to the car to make minimum weight with my batteries.
For me at least, if I went to USVTA legal batteries, I would get the heaviest 5000mah packs I could find.
#5529
#5530
Tech Legend
thats great news.
Where is the best place to order these bodies from online?
Also, if I recall correctly you want to get decals for these from someone else? If so, who do you all recommend for these bodies?
I got a funny feeling the challenger bodies we painted won't last very long ...
#5534
Try running maximum motor timing
Make sure motor rotor is free and not over shimmed
Make your drivetrain ultra free running (no binding of hub or layshaft bearings)
Degrease all bearings for reduced rolling resistance
Lube your cvd/cva joints (rusty neglected cvd's are not fast)
If running on carpet watch/remove carpet fuzz from rotating parts/bearings
Proper gear mesh of pinion and spur gears (not overtly tight causing drag)
Loose belt tension for reduced drag (or shim diffs properly on shaft driven cars)
Run min rear toe in and min front toe in or out to reduce scrubbing of top speed. (I only run .5°-0° rear toe in on my VTA car for max top speed)
#5535
Take your pick of 5000 mah batteries - I've used OHP, Thunderpower, Reedy and CRC over the years - none of which gave me a clear-cut advantage over the other batteries available. This is TRULY one of those situations where you choose your favorite reputable manufacturer, buy one of their batteries, and go racing.
