Hobbywing Justsock ESC /17.5 turn system >
Old 03-04-2012, 07:13 PM
Norman2's Avatar
Default Hobbywing Justsock ESC /17.5 turn system
Hi, I am planning to run a CRC Genx-LE pan car in the Oval series in
our local track. Rules call for single cell (3.7 volts) and no timing.
I need some help as the esc has a lipo cut off at 3.0 volts. I usually run
my fast electrics boats with 2X 2S 1p lipos in series which gives me 14.8
volts and the esc cutoff is set at 3.7 volts. My question is if the Hobbywing
Juststock esc can run with a single cell lipo. I have read all the instrucions
and can't find the answer. It seems to me that my run time will be very short. Any advice will be greatly appreciated. Regards
Norman2
Norman2 is offline
Old 03-04-2012, 07:24 PM
rcduder's Avatar
Norman2
from everything i have read about it (specs and everything) i don't think it can but if you didn't know this hobby-wing makes a 1s specific sensored racing esc
http://www.ebay.com/itm/Hobbywing-XE...item1e6b02bc32
it is a lil more expensive then the justock for sure though (don't know if your trying to buy on a budget or not)
rcduder is offline
Old 03-04-2012, 07:34 PM
big_ads's Avatar
Trader Rating: 88 (100%+)
I have used the juststock one for 1s racing...works great but you need a booster or receiver pack. The 1s is a good option for stock racing because you do not need a booster. But if you are going to get one I would go through someplace like Stormerhobbies.com or CRC directly. The black case is the v2.1..the most current one.
big_ads is offline
Old 03-04-2012, 07:49 PM
Just to specify:
The the one he wants is the 120A 1S. Its available in both Blue And Black. the V2.1 is the older model (just as good), but needs 2S-3S.
Shawn
Shawn68z is offline
Old 03-05-2012, 07:06 AM
big_ads's Avatar
Originally Posted by Shawn68z
Just to specify:
Shawn
So the 1s one is actually the 2.0 then? I guess thought that the blue case was the older version because it isn't really available anywhere but ebay.
big_ads is offline
Old 03-05-2012, 07:23 PM
I would stay look to ebay the Hobby Wing stuff. If you can afford it go with a quality product. Remember money buys speed. You get what you pay for.
martin660 is offline
Old 03-05-2012, 07:32 PM
rcduder's Avatar
well the hobbywing stuff is the main racing equipment used by a lot of locals everywhere and i havent heard anything bad about them
rcduder is offline
Old 03-05-2012, 07:37 PM
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Team CRC sells hobbywings. Brain and the crew there are very good people and are always just a call away if you need anything.
here's a link to them
JUSTOCK http://www.teamcrc.com/crc/modules.p...prodID=7719212
1 Cell with built in booster I run this speedo in blinky 12th and WGT great speedo.. http://www.teamcrc.com/crc/modules.p...prodID=7719207
Ron Goetter is offline
