Like Tree209Likes
Exotek F1R
Old 12-24-2011, 10:04 AM
  #121
Hey Mike,
One of the things I always disliked about Tamiya's designs in F1 is their tenancy to use long screws that go all the way through the car and are fastened on the top. This makes maintenance a pain as you have to undo stuff from the bottom just to take the top stuff off like the upper plate on the old F103. The F1R gets rid of almost all of that...the only 2 long screws left that are an issue are the ones that go through the rear of the servo mount into the upper arm pivot balls. Have you considered releasing a servo mount where that hole is threaded instead of smooth? This would make things simpler...On my F109 when I converted it to the F104 front end I cut that part of the servo mount off then used a 1/2" aluminum stand off that I tapped to 3mm. This worked great for the most part except the aluminum on the stand off I used is too soft and tends to strip out easily. A threaded servo mount would really make things a lot easier for a lot of people.
InspGadgt is offline
Old 12-24-2011, 12:51 PM
  #122
MaxSp97's Avatar
You meant this...
http://www.exotekracing.com/f104-bolt-in-servo-mounts/
[QUOTE=InspGadgt;10077632]Hey Mike,
One of the things I always disliked about Tamiya's designs in F1 is their tenancy to use long screws that go all the way through the car and are fastened on the top. This makes maintenance a pain as you have to undo stuff from the bottom just to take the top stuff off like the upper plate on the old F103. The F1R gets rid of almost all of that...the only 2 long screws left that are an issue are the ones that go through the rear of the servo mount into the upper arm pivot balls. Have you considered releasing a servo mount where that hole is threaded instead of smooth? This would make things simpler...On my F109 when I converted it to the F104 front end I cut that part of the servo mount off then used a 1/2" aluminum stand off that I tapped to 3mm. This worked great for the most part except the aluminum on the stand off I used is too soft and tends to strip out easily. A threaded servo mount would really make things a lot easier for a lot of people.[/QUOTE]
MaxSp97 is offline
Old 12-24-2011, 01:09 PM
  #123
Oh are those threaded? I didn't think they were.
Where do I get those 6mm blue spacers for the servo saver shown in the pic?
Old 12-24-2011, 01:31 PM
  #124
MaxSp97's Avatar
Yes! It's threaded. I used 3x20mm screw for lower chassis and 3x16mm upper desk. You could get the spacers 3x4 or 3x5 from 3Racing.
Check TQ Racing Sean may have all the parts.
MaxSp97 is offline
Old 12-24-2011, 05:49 PM
  #125
texastc's Avatar
All my parts finally rolled in. TC is a happy camper. After I help Santa put some toys together Ill be all over finishing the F1R. And the CRC, and my brothers F109. Maybe Santa will stick around and help me a bit.
texastc is offline
Old 12-25-2011, 12:06 AM
  #126
Ok I got the servo mount ordered as well as a few other stuff I wanted to get before but had to wait. Have a servo and a receiver out for repair and I wasn't sure if the warranty was going to cover them so I was holding a lil on the side to pay for that...well they are both being covered
Old 12-25-2011, 12:21 AM
  #127
Ok I'm looking at my Pit Shimizu tires and Tamiya foam rims now trying to figure this out...on the outside edge of the rim does the tire glue to the outside of the rim? It kinda looks that way but I'm not sure. One side of the tire has a smaller ID than the other side of the tire.
Old 12-25-2011, 01:13 AM
  #128
Odin544's Avatar
Trader Rating: 93 (100%+)
The big lip on the tire goes towards the outside of the rim. I've got a little trick for glueing those wheels but I'm not going to try to type it all up from my phone. I'll try and post how I do the outer bead tomorrow. In my experience if you just peel it back and glue them they don't come out very true on the rim. I've ruined at least 2 sets until I figured out a good way of doing it. I have a set I need to glue so maybe I'll do a video of it if it helps.
Odin544 is offline
Old 12-25-2011, 12:56 PM
  #129
Trader Rating: 24 (100%+)
MERRY CHRISTMAS Mike and thanks for offering some great products.
Have a question regarding servo mounts and overall balance of the car.
Been waiting for the new laydown mount but that requires the use of shorty packs.
I'm wondering if anyone is thinking that the use of these "bolt in" servo mounts might be a better choice overall since you could then use normal size batteries OR shorty packs with little effort and could use them to help balance the car for different conditions.
Thoughts ??
Evoracer is offline
Old 12-25-2011, 02:49 PM
  #130
[QUOTE=MaxSp97;10077436]Merry Xmas everybody...[/QUOT
Hey Max, Is that one of the old Paul Oxman cards?
alphacat is offline
Old 12-25-2011, 03:24 PM
  #131
MaxSp97's Avatar
[QUOTE=alphacat;10080969]
This one is from Concepts International.
http://www.conceptsi.com/index.htm
MaxSp97 is offline
Old 12-25-2011, 04:36 PM
  #132
durtbag's Avatar
Originally Posted by Odin544
The big lip on the tire goes towards the outside of the rim. I've got a little trick for glueing those wheels but I'm not going to try to type it all up from my phone. I'll try and post how I do the outer bead tomorrow. In my experience if you just peel it back and glue them they don't come out very true on the rim. I've ruined at least 2 sets until I figured out a good way of doing it. I have a set I need to glue so maybe I'll do a video of it helps.
please do. i suck at mounting tires, there has to be a better way.
durtbag is offline
Old 12-25-2011, 05:08 PM
  #133
texastc's Avatar
I ruined my first set of Pits for F104 rims. I glued them backwards. It was an expensive mistake. The right way didn't look right at first, but today I got to messing with a new set. Like Odin said, the big lip goes on the outside. Perfect.
texastc is offline
Old 12-25-2011, 05:37 PM
  #134
CR0SS's Avatar
I was unsure when I got my first set. So I just mounted them with no glue and put them on the car. This quickly showed which way to mount the tires on the rims.
CR0SS is offline
Old 12-25-2011, 05:39 PM
  #135
texastc's Avatar
Common sense, patience, and me do not often collide in the same sentence. I never learn lol
texastc is offline
