New CRC Gen Xi 12th car.....
#736
#738
I built a kit the other day that had already been opened and it had an 80 tooth in it. But the CRC spurs are labeled. It shouldn't be hard to find.
https://encrypted-tbn0.gstatic.com/i...H51o9hRLFri4Wg
#739
Thanks Eric,
My eyes are crap and i was hoping to avoid counting that many 64 pitch teeth. Thought, with enough owners somebody might just shout it out quick. Kind of disappointing the instructions dont do a bit better job at identifying stuff in the new kit, had to ask the weight of the shock oil and damper lube as well.
Thanks Again for responding!!
Kevin
Kevin
#741
Thanks Eric,
Kevin
Kevin
E
#742
Hey Brian
You have a PM
Jeremy
You have a PM
Jeremy
#745
Shoe Goo is more than strong enough. I've never had any electronics come loose that were Shoe Goo'd in. In fact if you do it wrong it will be next to impossible to remove without messing up the chassis...that's really easy to avoid though. To take anything off that has been Shoe Goo'd to the chassis you need to be able to slice the glue with a sharp blade and then it will pry right off. So make sure when using Shoe Goo not to push the component down too far. You need to leave enough gap to wiggle an Xacto blade into.
GW
#748
Amazing how quickly this thread has quieted down -- I guess the Xti thread has taken over all of the CRC 1/12 spotlight. A lot of us still have this car (Xi), right?
Think the Xti is that much better??? I know it has the "cool factor" of the adjustable rear pod...
