New CRC Gen Xi 12th car..... >
Old 09-03-2012, 08:29 AM
  #676
Trader Rating: 38 (100%+)
My work schedule has freed up and I'll be off to the IIC. Only problem is I've only raced the Xi on a Low-Medium grip carpet due to lots of dirt from the adjacent off-road track. Anyone have tire suggestions for the IIC? I've been quite happy with the Magenta or Pink front and Pink rears up to this point but don't want to end up not having what I need while I am there. I prefer a car with a ton of steering and to use my driving to get the car around the track instead of putting the 'right' amount of push in the front end like a lot/most drivers do. I'll be running 17.5 there.
linkless is offline
Old 09-03-2012, 08:35 AM
  #677
WIITA's Avatar
Trader Rating: 43 (100%+)
I would suggest a Graylow/chrome combo for the iic.
WIITA is offline
Old 09-03-2012, 11:54 AM
  #678
From the CRC forum here: https://www.teamcrc.com/crc/modules....ewtopic&t=2291
"Hey Frank,
Burt from Hawaii here...just ordered me a Gen Xi with the inline conversion and the shorty pack for the IIC I'm planning on running the 13.5 blinky class and was hoping you had a good setup for the car on that track. See ya at the IIC!
Burt"
"Hi Burt,
The box stock setup is pretty good, we put it in there for a reason
For going to Veags I would do the following things:
.50 front springs
Red or white center spring
10k in the tubes
-.5 degree of camber
10 degree caster blocks, all shims back
White side springs with just a little preload
1.5-2.0 mm rear droop
Magenta front pink rear or chrome front grey low rear tires
For 13.5 blinky I would think the R8C body, if you need more rear bite, use the Black Market body
Ride height, 3.25mm front, 3.5mm rear
That should do it. If you need anything else, feel free to ask or come see us in Vegas!
Brian Wynn
Team CRC"
InspGadgt is offline
Old 09-03-2012, 01:27 PM
  #679
Team EAM
Trader Rating: 79 (100%+)
What is a chrome??
EA
EAMotorsports is offline
Old 09-03-2012, 01:46 PM
  #680
Trader Rating: 19 (100%+)
Originally Posted by EAMotorsports
What is a chrome??
EA
http://teamcrc.com/crc/modules.php?n...prodID=7719216
COLD AS ICE is offline
Old 09-03-2012, 01:47 PM
  #681
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Front tires
Magenta inside 2/3
Black Outside 1/3
RedBullFiXX is offline
Old 09-03-2012, 01:50 PM
  #682
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
What is a chrome??
EA
its a 70/30 gray/silver combo tire like the oval guys run on the RF.
Ron Goetter is offline
Old 09-03-2012, 02:07 PM
  #683
GMartinez's Avatar
Trader Rating: 91 (100%+)
I have been using Gravity rc Hard fronts for high bite they have been more consistent IMO
GMartinez is offline
Old 09-03-2012, 02:39 PM
  #684
Team EAM
Already looked there...Didnt give the answer
Originally Posted by RedBullFiXX
Front tires
Magenta inside 2/3
Black Outside 1/3
Incorrect
Correct. Had to call to find the answer. LOL
Thanks!
EA
Old 09-03-2012, 02:45 PM
  #685
S.Stew's Avatar
Incorrect
Thanks!
EA
So when would you use chrome as opposed to say black ?
S.Stew is offline
Old 09-03-2012, 04:07 PM
  #686
Team EAM
My guess would be to get a little more corner steering but not as edgy as a black. I will try some soon. I had missed out on this release!
EA
Old 09-03-2012, 06:11 PM
  #687
Pretty much been my exact experience with them. We typically don't have high enough bite to run these, but I ran the Chrome/Grey-Lows @ the Carpet Nats and they worked well. I switched from the Blacks to Chromes during qualifying and the car was a fair bit smoother on center but seemed to have a bit more mid corner front bite.
JamesL_71 is offline
Old 09-03-2012, 06:39 PM
  #688
I used chromes last year a few times. For me they gave more bite than black, but less bite than grey, like right in between black and grey. The only drawback I found was they wore really fast, almost as fast as grey fronts do.
martymiller is offline
Old 09-03-2012, 10:05 PM
  #689
Trader Rating: 17 (100%+)
in for more info on that chassis with the backwards servo and rear diffuser. my next chassis will be a 1/12 for 17.5 racing in the winter, and i want in!
cmross13 is offline
Old 09-04-2012, 08:26 AM
  #690
al dente's Avatar
the new car will be out soon. be patient. trust me......if its not like the have all the kits sitting there ready to go and are just holding them. they are waiting on a few more things to come in. once they have everything, the car will be released.
al dente is offline
