Team Much-More cell master v1
#1186
i'm planning to get one... give me some positive and negative feedback... is there only 1 version of cell master?? tnx.. need help ASAP...
#1188
Originally Posted by shift
Hi there,
I have encounted a problem when charging in ctx mode. what keeps happening is for the first step the charger runs fine then when it gets to the second step it charges for a couple of seconds then stops as if it has peaked but the voltage sometimes isnt evn dropping when it stops then starts again. this goes on for a while then it says check clips but all the clips are fine. im using 3700's and the profile im using is
step 1:3000-7.0a
step 2:3030-0.2a
step3:5000-4.0a
has anyone else encounted this problem before if so how did you fix it.
any help would be appretiated
Cheers, Liam
step 1:3000-7.0a
step 2:3030-0.2a
step3:5000-4.0a
Cheers, Liam
Originally Posted by YR4Dude
Who and where is selling the latest Much More products online?
I've looked all over including E-bay.
I can barely just find the CTX charger in black let alone any limited editions.
Can anyone provide a link?
BTW Speedtech is out of stock. Please provide link to someone with good stock on Much More products. Thanks
Originally Posted by Fervidsea
At the track today, temp was about 85, nice cool breeze, CM wasnt in direct sunlight and the unit said "HOT" then shut down. Temp was only at 36. Plug it in now and the top line of the LCD is black the rest is clear. Any ideas?
#1189
hi nexus racing... is there any factor charging differences in the upcoming ctx versions??
#1191
#1192
Originally Posted by Nexus Racing
None that we know of. The Black CM will still be produced, and the Andy Moore and Marc R editions are limited production only.
#1193
ohh i see.. im planning to get one.. i just a lil curious about the long lockout feature of CM... is the cell master long lockout timed in minutes??? not like pitbull x3 it is in mah lockout.... im just confused...
#1194
Hey Nexus,
I heard that CTX Cellmaster owners don't need to buy a new model if ever it comes out because the current model can be upgraded through a computer update. Updating the v.1.0 to v.1.1 or v.2. Is this true?
#1195
Originally Posted by Nicadrauspro4
Hey Nexus,
Just to be clear to everyone, though, the only update made to the CM since its release has been the magnetic temp sensor (obviously not software-related).
#1197
does it mean that version 1 is outdated when it comes to charging????
is this a good charger in terms of charging??
#1198
#1199
Originally Posted by A. Rhodes
No, the V1 is not outdated when it comes to charging. The Cell Master is one of the best chargers on the market today. Go to any big race, and you will see cell masters (and other MM stuff) in just about every pit.
#1200
There is no current possibility of users performing updates (meaning there is no type of data cable available). It might be possible, but I'm not sure. What you heard was probably just a rumor.
