Ta04r...
#151
the .4 module and 64 pitch gears are the same, you can actually interchange them. right now, i use a ta-04 spur and hpi pinion on my hpi pro 2. they mesh pretty well.
as for the pinion priices, man those are stiff!!!! tamiya .4 module aluminum pinions sell here in the philippines for only 8 USD a pair!
as for the two motors, jcr is correct. although i personally like the type t better. acceleration is better than with the type r. they also have nearly the same top-end.
#152
I,ve been reading some of your postings on this topic, and havent recieved my TA04-R yet. My question is I take it that it comes with a metric spur, I think someone said 120T. I do not have access to tamiya pinions or Hpi. I can get RRP, and kimbrough all day long. Can I just use 48, or 64 pitch gears instead? I'd rather use 48 pitch sinse I run on outdoor aspault thats not always the cleanest surface.
Can anyone give me a suggested 48 pitch combo to start with, using a MVP stock motor?
#155
for 48 pitch, use this. 93 tooth 48 pitch rrp and 30 tooth pinion.
#156
Type R pictures
The pcb looks to be removable yes...
#157
ecrap: the prices are in Canadian dollars and Tamiya pinions comes in a pair.
as for gearing if i look back at the gearing of my Yokomo the closest ratio to it was 120 x 40 so i think 120 x 40 is good. I've seen a 120 x 40 on a MVP so it should work.
tried out the 04R for the first time yesterday and it was easy to get it going but i still need more steering for the stock setup so any help?
#158
you could try these:
Harder springs for rear
move camber link for front to inner hole (basically make the link longer)
Haven't tried the lower hole, but I guess that will give even more turn in. Beware spin outs.
#159
those PCB is actually SMT capactitor...
why do u want to remove them??
#160
how much camber are you running now?
I'm using -1 in the front and 0 in the rear. but i've also found out that a tighter differ will have more steering but too much for the fast turns.
#161
But seriously no idea, henry @ rc speedway I believe he mentioned they were removable, not only convenient but also in case of blown cap just replace the pcb. Would be more expensive huh?
#162
Diff tightness was recommended to me - just tight enough that it does not slip. And then loosen the rear slightly. I dunno, but after I was told to do this adjustment my car can grip the road after a high-speed hairpin, previously it's a spinout or drift towards the wall.
hths. My 04 is still full time 4wd, can't find any one-ways.
#163
i dont know if u can actually remove the pc board, guess you could pry them or something...
#164
ya i had the same problem with the diff. a tight diff can't go through any fast turns without spinning.
well more steering i might try more camber or less toe.
#165
Greetings!, I just recieved my TA04-R Altezza today in the mail, and holy WOW does that body look awesome! I have one quick question, I've started putting the assembled front and rear transmissions on to the tub chassis, and noticed the front belt is pretty tight, is this normal? Do you think it will lossen up? Its not like it wont rotate, but its just tighter than any previous T/C I have owned (Pro2, MR4-SP).
