Where to solder the diode >
Old 09-30-2004, 09:49 AM
  #16
kufman's Avatar
With the short lengths of wire that we use in RC, I don't see there being a problem with soldering the diode on the ESC. In some respects it might be better to keep the diode away from a hot motor anyway. just my $.02
kufman is offline
Old 09-30-2004, 10:04 AM
  #17
imjonah's Avatar
Default How to place diode
The diode has a plus and minus pole/lead do you solder it in line on the positive wire between the ESC and the motor
ESC +____________+diode - ___________ + motor
or do you Solder it across from the plus to the minus wire?
ESC+ _________________ +diode _____________ +Motor
ESC - __________________ - diode ____________ - Motor
imjonah is offline
Old 09-30-2004, 10:54 AM
  #18
c-lyon's Avatar
Your second option. Pos to pos to pos and neg to neg to neg. The pos has a silver stripe round the end.
c-lyon is offline
Old 09-30-2004, 03:33 PM
  #19
hierog's Avatar
Default diodes
i put em on the esc and the motor - too many can't hurt, especially when I glitch as much as I do. I've started to use noise filters though, and boy do they work wonders!
hierog is offline
