Team Losi JRXS
#4906
Originally posted by Tim_Gaukroger
My JRX-S arrived today. First one in Australia as far as I'm aware.
Started putting it together tonight, goes together far better than the old XXX-S G+ did. Am very pleased so far with the only problem being not lining up the holes to slot the small shaft through for the spur gear.
Some superb features, belt / diff height adjustment really caught my eye straight away.
Doesn't look asif I'll be braking my outdrives in a big hurry either, beefy as!!!
Just wondering though, who's broken what at this stage? Are the front arm's a weak point? The rest of the car looks very strong and am wondering if this is going to potentially be a minor downfall.
Tim
Tim
#4908
there was no problem other than the way i assembled the gear first time. The pin you have the spur press onto wasn't alighted with that of the gear, so i couldn't put the pin in at all.
All the usual stuff to order-extra steering knuckles, arms, pivot block set, caster blocks.....
#4909
Originally posted by T. Hodge
It should be ready by the end of May.
The Losi web site updates are awesome!
Thanks again.
#4910
Im woundering if Losi is going to be making the Red Anodized Pivot blocks and support like they had for the XXX-s
#4912
Originally posted by Chandler
The Thing I Broke Easy was the front Bumper and the Front Pivot Block.. Thats to only weak spot I see with the car...
#4916
Hope that helps! I've taken my car apart a dozen or so times by now and have noticed that Losi has made many parts in such a manner that incorrect assembly is impossible. After building many vague kits in the past, Losi's approach is refreshing!
#4918
Yes you have to trim about 1/8" off of each ball cup.
Yes bring on the Blue!
Later,
#4919
ideas? methods on doing this?
