Team Losi JRXS
#2881
Originally posted by FIRE RIDER
As i was reeding back a few posts and i noticed someone said that it ships today(monday) is that true??????
Becasue i would realy like to get my hands on one before my clubs 12th annual carpet challenge this weekend(the 18-20).
#2882
R/C Tech Elite Member
Re: Francis wins with JRX-S
Originally posted by JRX-S Bill
Matt Francis displayed some excellent driving skill in qualifying 1st and then carrying it all the way to the finish line at the California Carpet Championships at Stockton today.
Barry Baker showed up today to only make the 4th round of qualifying. With only a few laps on the track, Barry qualified in second and hounded Matt throughout the first half of the race to finish second overall. Barry was certainly hot on certain sections of the track.
#2883
Originally posted by Gearhead3
to help fit the very slightly bigger 3700 cell i would guess.
#2884
Originally posted by Randy Caster
I'm not sure about that because I put one of my GP3300's into the tray and they sat perfectly flush with the bottom (needless to say I was impressed) but I think the 3700's are supposed to be a little larger around, I could be wrong though.
#2885
I would say that the tray was 1/16-1/8" longer than before...Does that count as "slightly"?
#2886
Picture time...
#2887
You are correct about the cell being slightly bigger around. but some here complained the cell would not sit low enough....So who knows execpt losi....LOL.......Just waiting to beable to build mine.
#2889
On Friday when Jr. was here doing some testing he gave me a little insite on how to wire and solder the batteries in the JRXS.
1)If you hard wire ( solder direct to the batts. ) you need to attach you battery bars towards the inside of you packs and angle them at a 45 degree angle towards the center of the pack. You will then be able to solder from the upper right hand side of the car between the belt and the upper deck.
2) The other way is to solder the bars on the same as above, then solder euro style connectors to the bar. This will position the connector in the saddle between battery 1 and 2, 5 and 6, then you will be able to push the male connector in from the left side.
Hope this helps.
One more thing. I have seen this car though the development stages for almost a year now and I can honestly tell you that on Friday the car was performing better than I have seen. Jr's was turning consistant laps and the car had no problem going in the direction it was pointed.
Hope this helps.
#2890
i know this is kinda early to make this suggestion since i dont have the car myself to play with, but could you solder the battery bar so that it flips away from the pack and make it any easier to solder to? the only problem would be gettin the pack in (this is where i need some help), how much room is there to 'roll' the pack into the batt. compartment?
#2891
Flipping it in shouldn't be possible. You should watch the Video of putting in the battery at www.jrxs.net . Maybe it's helpfull.
I would say Euro Style connectors is the best way of connecting to the pack. I'm not sure if you would be able to say, while driving, if XYs car has Euro style connectors or is hard wired.
#2892
The Evicerator
Flipping the battery in is possible with the production car...the opening for the battery is larger and allows for more manipulation of the battery.
#2893
Regional Moderator
More than getting the pack into the car would be a problem, I would think finding a good way to store your packs would be an even bigger problem.
No (production) battery boxes I know would have room for a battery bar bent the other way. At least not bent enough the other way to allow it to clear pass the belt and make soldering any easier.
#2894
so no confirmation of the shipment of these puppys yet?
#2895
I just called horizon and talked to the guy down in consumer support and he said he hasent seen the car or heard of any release date or maybe it was a lie
